C7 sun visor electrical plug
Old Dec 13, 2019 | 08:04 AM
dickster4444's Avatar
dickster4444
Default C7 sun visor electrical plug
My 2014 needs a replacement passenger side sun visor. This visor has a lighted mirror. I took it apart but was unable to get the plastic electrical plug apart. How do you unplug this piece?
Old Dec 13, 2019 | 08:08 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
At the most, it may have a locking tab on it that needs to be released. I've had mine off the car for some stuff I've done and don't recall the exact configuration on the plug.
Elmer
Old Dec 13, 2019 | 08:54 AM
dickster4444
I tried what appeared to be a release tab but nothing happened.
Old Dec 13, 2019 | 08:59 AM
2019GSTX's Avatar
2019GSTX
Lurker
St. Jude Donor '19-'20
https://www.corvetteforum.com/forums...-sunvisor.html
Look at post #8...3:25 in he removes the sunvisor....just need a little flat blade screwdriver
I changed mine out for a Homelink version, its easy!
Old Dec 13, 2019 | 09:06 AM
2019GSTX's Avatar
2019GSTX
Lurker
Sometimes you wish you had 3 hands. 1 to hold the bottom part of the connector, 1 for the screwdriver and then one more to pull the connector top off when you release the tab
Some of the GM connectors are tricky, you have to ascertain where it splits apart and what locks them together
Let us know how you make out, if I have to I can go pull mine out and take a picture of it....if I can find a torx bit at work!
Old Dec 13, 2019 | 09:21 AM
dickster4444
Thanks guys, I'll try this again tomorrow---not home now. I'll let you know if I can get it to release.
Old Dec 13, 2019 | 09:26 AM
2019GSTX's Avatar
2019GSTX
Lurker
No problem...I'll post up a pic later you can refer to
Old Dec 13, 2019 | 10:14 AM
Good luck - am interested in how the connector releases. I like to keep info like this on file just in case I ever need it.
Old Dec 13, 2019 | 10:47 AM
dickster4444
Thanks!!!!!!
Old Dec 13, 2019 | 02:52 PM
2019GSTX's Avatar
2019GSTX
Lurker
That little triangle in the middle of the channel at the top is the lock
Insert a small screwdriver into the connector to release the lock while trying to pull both ends of the connectorapart
The small portion of the connector should slide out
This the lock, it will click back in when you re-assemble with the new sun visor connector
Old Dec 13, 2019 | 03:00 PM
dickster4444
WOW I had been trying to push that little tab down. I was afraid if I pried under, where you did, it would break the plastic.
Thank you for your "above and beyond" effort to help me out.
Have a Merry Christmas and wonderful New Year.
Hope I can help you some day.
Dick Jones
Old Dec 13, 2019 | 03:15 PM
2019GSTX's Avatar
2019GSTX
Lurker
It’s pretty robust, should be ok.
‘I probably unlocked it 3 or 4 times taking those pics, really need 3 hands.
No problem! Between the car and Harley I have to sometimes call on my friend that has a lot more electrical connector experience than me! I can fight one for hours and then he unlocks it in seconds.
‘Same to you and yours Mr. Jones...
Old Apr 29, 2026 | 11:06 AM
WHealy2's Avatar
WHealy2
Cruising
Just a quick reply to this to share recent findings. Thanks to those that gathered this original content.
The part number is still valid for black non suede homelink visor. Of course when ordering don't use a LT1 VIN as that part number doesn't match as it didn't come with the homelink. A point I missed initially. Use an LT2 VIN or above.
The wire plug was attached to my visor. I assume that was because I have a lit vanity mirror in my visor. I assume if you have one of these you will be removing the wire plug from the visor and not the holding position shown in the video.
To C7 sun visor electrical plug
