Battery recommendation
Old Dec 31, 2019 | 03:36 PM
tonyb47's Avatar
tonyb47
Default Battery recommendation
My vette won't start, had the charger on it, lights showed charged , but wouldn't start today. Its a 2015 LT1 coupe which I just purchased in October, probably original battery. checked voltage and only reading 10v, after tryin to start it, I think I have a dead cell. Any recommendations on a battery, should I stay with ACDELCO, or a Durolast or interstate. Chevy dealer wants $183. for ACDELCO
Old Dec 31, 2019 | 03:46 PM
Kevin A Jones's Avatar
Kevin A Jones
I've Bought/Sold/Warrantied a few hundred thousand batteries in my life and all considered the below is the one I will put in my GS when the time comes. It should run you around $150>$160.
Old Dec 31, 2019 | 04:51 PM
badhabit_wb's Avatar
badhabit_wb
I like the odyssey 48-720. It's a direct fit and a better battery. It is more expensive though.
Old Dec 31, 2019 | 05:04 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Hendrick put a 42 month Delco in my 2014. I had it changed out August 2018 before it crapped out.
Old Dec 31, 2019 | 05:32 PM
Kevin A Jones
How much are they going for now?
Old Dec 31, 2019 | 05:56 PM
Red08's Avatar
Red08
Is that an AGM battery? 42 months replacement is not bad.
Old Dec 31, 2019 | 06:00 PM
badhabit_wb
​​​​​​250 or so I think
Old Dec 31, 2019 | 06:39 PM
CP's Avatar
CP
I just replaced the OEM battery that has been in my car since 8/2014. 5+ years!!!! Replaced it with another one just like it.
Old Dec 31, 2019 | 08:16 PM
That is the battery I put in my car last spring when I replaced the original one.
Old Dec 31, 2019 | 08:38 PM
jdk541's Avatar
jdk541
St. Jude Donor '22-'23-'24
Old Dec 31, 2019 | 08:41 PM
v.vet's Z06's Avatar
v.vet's Z06
ACDELCO. That is all I used in my 2004 and 2008 Corvettes. The 2004 never needed replacing before I bought the 2008. In the 2008 I replaced in 2013 and when I traded for my 2019 in 2018 it was still strong. When the battery in my 2019 Corvette needs replacing it will be ACDELCO I choose.
Old Dec 31, 2019 | 09:36 PM
jtranger's Avatar
jtranger
Where is the best price for the AC 42 month? I imagine it is more expensive from the dealer.
Old Jan 1, 2020 | 09:37 AM
Kracka's Avatar
Kracka
I did the ACDelco Gold as part of my 5-year freshening up to catch it before the factory battery failed. I let the dealer do it and it wasn't badly priced. $125 + $25 install.
Old Jan 4, 2020 | 06:02 PM
emperors61's Avatar
emperors61
I used ACDelco 48AGM Professional AGM Automotive BCI Group 48 Battery both in my CTS-V and C7 Z06. You can get it for around $170.
Old Jan 5, 2020 | 12:04 PM
Sixgun95's Avatar
Sixgun95
Costco - Interstate AGM 42mo battery was $158, after returning my old battery with the $15 core I paid $143. Direct replacement, exact dimensions as the OEM battery.
Old Jan 5, 2020 | 12:10 PM
BB767's Avatar
BB767
Default Difference between a ACDelco 42 - 48HPG or a 48PG
Looking at the ACDelco site they list both an AC42 Professional part# 48HPG or the same thing with part# 48PG. The specs for both appear identical.
Anyone know the difference between them and which would be the correct replacement for 2015 Z51? Thank you.
Thomas
Old Jan 6, 2020 | 09:28 AM
tonyb47's Avatar
tonyb47
Thomas
I just replaced the battery in my 2015 stingray, I went to a chevy dealer and they used my vin# to get the part number its GM88865244 its a exact replacement, I put it in Friday and car started up fine. You can do the same, go to a dealer with your VIN
To Battery recommendation
Old Jan 6, 2020 | 09:52 AM
roadbike56's Avatar
roadbike56
A comment about the OEM battery. The OEM battery in 2014 is a 36 month battery. AC Delco doesn't offer a 36 month battery anymore. It was replaced by a 30 month battery. AC Delco used to offer a 48 month battery. That is no longer available and has been replaced with a 42 month battery. Hendrick offered both batteries when I replaced, but I went with the 42 month. It is not an AGM battery. If I had it to do over again, I would have bought the AGM if it was correct for the Corvette. I don't know what came with newer years, but be aware, somewhere along the way Delco changed their warranty and the old OEM numbers may not apply.
Old Jan 6, 2020 | 10:08 AM
Corgidog1's Avatar
Corgidog1
Thomas
i actually know the difference as I had this choice several months ago when I got a new battery from my dealer. The 48PG was 159 and the 48PGHR was 189. The PG has a higher CCA while the PGHR has a higher reserve. (HR meaning higher reserve) the PGHR cost more due to the thicker plates required for a higher reserve. Now as to which is more important higher reserve or more cranking power—- If you do not leave your car outside in very cold temps than higher reserve is more important due to the vast electronics of modern cars. The electronics part and higher reserve is right from AC Delco website.
Old Jan 6, 2020 | 11:17 AM
The Successful Plumber's Avatar
Costco same warranty probably 2/3 the cost. In the C7 you can’t see the AC Delco decal on the battery anyway. Just put one in my truck.
