Headlight sensor
Old Jan 29, 2020 | 11:59 PM
gfrazzle's Avatar
gfrazzle
3rd Gear
Default Headlight sensor
Where is the headlight auto sensor located?. Mine is not working correctly. Dash presentation intermittently goes very dark- apparently thinks it's night and dimmer won't adjust.
Old Jan 30, 2020 | 12:13 AM
R8Z51's Avatar
R8Z51
10 year member and this is your first post? Lmao
I believe it's located right in the middle of the dash.
owc6's Avatar
owc6
It's the dome on the dash.
Old Jan 30, 2020 | 12:26 AM
gfrazzle's Avatar
gfrazzle
3rd Gear
16 year member and haven't had a problem with either my C2 or C7. Thanks for the response!
Old Jan 30, 2020 | 01:30 AM
Grand Slam's Avatar
Grand Slam
Around dusk my DIC occasionally goes dark as the sensor gets confused about what light is present.
Old Jan 30, 2020 | 05:38 AM
cowboy casey's Avatar
cowboy casey
I have 80% tint on my windshield and a dashmat and mine thinks it night 50% of the time during the day... I have gotten used to it.. The things we do to keep the dash from failing and delamination...
Old Jan 30, 2020 | 08:32 AM
Corgidog1's Avatar
Corgidog1
Make sure nothing is blocking the sensor. Had a similar problem as a result of my ez pass blocking the sensor.
Old Jan 30, 2020 | 09:06 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
When your alarm is setting or set, the red bump on the dash that does all the flashing? Well, that is also the day/night sensor that turns your lights on/off.
Elmer
Old Jan 30, 2020 | 09:49 AM
4thC4at60's Avatar
4thC4at60
95,000 miles on my C7 dash looks fine.... no mat and certainly not 80% tint on my windows....
Old Jan 30, 2020 | 11:43 AM
cowboy casey
You must have a 1LT or 2LT... The 3LT leather dash falls apart, delaminates, and it costs about $3,000 to fix, many threads about this... Just trying to keep mine looking like new...
Old Jan 30, 2020 | 12:46 PM
madrob2020's Avatar
madrob2020
If you mean exactly what you say, 80% means it allows 80% of light to enter. By the way C7s have all windows at 70% from factory. It is printed in TINY words on each window (which is less allowable)than you installed. If you have ceramic type tint I guess it’s possible that would interfere with the headlight’s sensor.
Old Jan 30, 2020 | 12:58 PM
slburgie's Avatar
slburgie
There is always one,, just saying.
Old Jun 27, 2024 | 08:51 PM
jmarkey77's Avatar
jmarkey77
This is my problem, just got a 70% tint. Annoying...
To Headlight sensor
