Tires rubbing
Old Jan 31, 2020 | 09:10 PM
Vette_Blue's Avatar
Vette_Blue
Default Tires rubbing
Hey guys, I just put on a set of new wheels and tires for my 2017 Corvette Stingray. The wheels are 19 x 9.5 +53 (offsets are approximate, I forgot what they are exactly) and 20 x 11 +73. Tires are Nitto NT555 275/35/R19 for the front and 305/35/R20 for the rear. I’m lowered all the way on stock bolts, and I have an issue. The tires are rubbing in the rear, but mostly on the driver side. I’m thinking that’s because of the pocket on the driver side. When I mean rubbing as well, I mean inside the wheel well in the back on both sides. Rolling the fenders would not help. I’m thinking if I raise the car back up on the stick bolts it might help, but if you guys have any incite on what I should do that would be great. I’m game to do just about anything, I just do not want to get different tires. That would just be so much lore stressful then it would be worth.
Old Jan 31, 2020 | 11:49 PM
geewez's Avatar
geewez
I think you have two issues going, the wheel offset might be a tad too much and the combination of the wider tires is adding to the problem First of all, there's no such thing as "rolling the fender lips" on a Corvette because the car is made of a fiberglass composite material, not metal. The first thing I'd try doing is raise the ride height to see if that'll stop the rubbing. If raising the ride height stops the rubbing then you know what you're going to have to do....
Old Jan 31, 2020 | 11:55 PM
Vette_Blue's Avatar
Vette_Blue
What will I have to do? I didn’t think you could roll the fenders, all my friends were saying to, and it just got engrained into my head I needed to specify that lol. As for the offset, I know it’s the average everyone who has those sizes runs.
Old Feb 1, 2020 | 12:57 AM
Avanti's Avatar
Avanti
Perfect storm to make it rub; do start by raising it and see what happens. Guess why GM does it (everything you changed) as they do? All the best.
Old Feb 1, 2020 | 07:34 AM
CraigStu's Avatar
CraigStu
1/4-1/2 inch wheel spacers?
Old Feb 1, 2020 | 08:00 AM
Vette_Blue's Avatar
Vette_Blue
Yeah I know they spec everything out specially for the car, I just don’t like my wheels inside the car.
Old Feb 1, 2020 | 08:02 AM
Vette_Blue's Avatar
Vette_Blue
I was thinking a small spacer might work, but I’m thinking raising the rear end might be the easiest, most cost effective way to do it.
Old Feb 1, 2020 | 09:04 AM
ImpliedConsent's Avatar
ImpliedConsent
Maybe raise the car back up on the lowering bolts?
Old Feb 1, 2020 | 09:55 AM
Vette_Blue's Avatar
Vette_Blue
That’s exactly what I’m thinking. Gonna try to do it today. Will update if that fixes the issue.
Old Feb 1, 2020 | 11:58 AM
If it stops the rubbing, you’ve solved the problem at no cost.
Old Feb 1, 2020 | 12:25 PM
SimCar's Avatar
SimCar
NCM Lifetime Member
NCCC Lifetime Member
It's rubbing because 305/35/R20 tires are too tall - they have a 28.4" diameter. You should be on 305/30/R20, which have a 27.2" diameter. For reference, the stock 285/30/20 Z51 size is 26.8" diameter. Spacers are not going to fix this... your offset is already on the low side. Raising the car will help. Be ready for a 5-6% speedometer error.
Old Feb 1, 2020 | 04:09 PM
JMII's Avatar
JMII
I think diameter too since the offset is only (6mm) 1/4" different. Since the offset is LESS then OEM the wheel is inboard which explains why its rubbing on the inside. Spacers would fix that but then the height means the outside would likely rub.
Old Feb 1, 2020 | 06:44 PM
SimCar's Avatar
SimCar
NCM Lifetime Member
Actually, the lower offset moves the wheel toward the fender, since it pulls the center line of the wheel closer to the mounting surface. The combination of width and offset makes the current wheel sit 19mm closer to the fender while also being 7mm closer on the inside. Adding a 6mm spacer will push things to 25mm further out than stock with the inside being the same as stock..
Old Feb 1, 2020 | 08:43 PM
Matthewstorm's Avatar
Matthewstorm
Rear wheel offset should be +76. Same thing happened to me. Had to exchange the wheels.
Old Feb 1, 2020 | 08:51 PM
SimCar's Avatar
SimCar
NCM Lifetime Member
His immediate problem is the tire diameter. It remains to be seen if that offset is going to work out. Ideal offset for that wheel and tire width is going to be around 82mm. If he's stuck with those wheels and has a problem, he may be able to deal with it by adding some negative camber and/or going to 295 width. I know that 305/30/20 on a 20x11 ET+82mm works on both the C7 and C6. There is probably a bit of wiggle room in that offset.
Old Feb 2, 2020 | 04:18 PM
Vette_Blue's Avatar
Vette_Blue
Hey everyone, I will post pictures soon! Bad news is I look like a monster truck. Good news is I don’t really rub anymore. I raised the car up almost all the way on stock bolts. There’s still some room to go up, so it’s not actually too terrible. I haven’t checked though where the bolts settled to, so I’m not sure exactly how much it’s gone back down. As for rubbing, it only rubs a tiny bit of I go over a large bump or something similar to that. Will definitely be keeping a close eye on it for the next couple weeks. I’m also going to be getting a smaller tire next time. I’ll make do with what I have though.
Old Feb 3, 2020 | 11:01 AM
JMII's Avatar
JMII
Sorry your right.
I run a 305/30-19 (yes 19" not 20") on a 10" wheel with a 75 offset on my Z51 fully lowered on the stock bolts. My tires show a tiny line on the edge that might be a rub but nothing transfers to the wheel arch. Could just be how the tread pattern / blocks wear on the track that causes this line.
https://www.willtheyfit.com/ provides a calculator
To Tires rubbing
