How much to fix
Old Feb 2, 2020 | 02:03 PM
giovanniguzman567's Avatar
giovanniguzman567
Default How much to fix
Old Feb 2, 2020 | 02:27 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
OUCH Time to get estimates...
Old Feb 2, 2020 | 02:28 PM
rrsperry's Avatar
rrsperry
Jawag, $5000.
Old Feb 2, 2020 | 03:42 PM
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
Whatever your deductible is ?
Old Feb 2, 2020 | 04:54 PM
Custom Corvette Accessories's Avatar
Premium Supporting Vendor
$6k
Old Feb 2, 2020 | 04:59 PM
lotecredneck's Avatar
lotecredneck
How long is a piece of string?
Old Feb 2, 2020 | 05:10 PM
dvilin's Avatar
dvilin
In excess of 4k for sure.
Old Feb 2, 2020 | 05:33 PM
Maxpowers's Avatar
Maxpowers
At least the panel below the door looks ok. It's glued to the frame and hard to replace. Looks like you need a new door.
Old Feb 2, 2020 | 05:35 PM
c6txvette's Avatar
c6txvette
Under 2k op
Old Feb 2, 2020 | 06:36 PM
Whatever the cost of a new door skin is and the labor to R&R and paint.
Old Feb 2, 2020 | 06:40 PM
Tommy79's Avatar
Tommy79
Probably cannot replace the door skin as the support beam may be bent. Door may need to be replaced...
Old Feb 2, 2020 | 07:38 PM
sTz's Avatar
sTz
The rocker looks like it can be fix, rather than replaced. It’s a PITA to removed as it is glued and would’ve certainly added to the cost. I’d say $4K’ish.
Old Feb 2, 2020 | 07:46 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
I had no one of my rockers replaced and it cost $2500 including paint.
Old Feb 3, 2020 | 12:04 AM
FX VETTE's Avatar
FX VETTE
$2,500 - $3,000 my best guess
Old Feb 3, 2020 | 03:25 PM
ROBWILKER's Avatar
ROBWILKER
$$$$ Lots. Hard localized impact with underlying internal part and panel damage.
Old Feb 3, 2020 | 05:55 PM
SingleTrackMinded's Avatar
SingleTrackMinded
Given your other post on the issues now with the inside of the door. I'm starting to wonder if trying to find an undamaged door from a junk yard and having it painted to match would not be the cheaper of alternatives...
Old Feb 3, 2020 | 08:02 PM
white90conv's Avatar
white90conv
Had similar damage to mine. Cost about $1200 for repair.
To How much to fix
Old Feb 3, 2020 | 09:15 PM
sTz's Avatar
sTz
Old Feb 3, 2020 | 09:25 PM
Maxie2U's Avatar
Maxie2U
Not sure why you would ask the forum how much it will cost to fix because we have zero facts to back up our GUESSES.
If I were you I would push the repair shop to replace not repair the door. In fact, I would bring it into the dealer first and get them to write up an order for the cost of a door replacement even before bringing it to a shop.
Old Aug 29, 2022 | 10:28 AM
15 Z51 conv's Avatar
15 Z51 conv
2024 C7 of the Year Finalist - Modified
Default Answer….
‘Twice the distance from the center to the end! 😂😅😅🤣😂
