Can someone share the procedure for setting my car's DIC like the picture posted below? I'm usually pretty good at this kind of stuff, but not getting on to this one. I believe this display setting came out with the 2018 model year. Thanks.
Try pressing the left arrow and then scroll down to Options, scroll thru that to display theme I think and then select TRACK.
Thats how I run mine and the car is at home so I cant run check.
Then you have to go back up to either info or performance to get the center to indicate tire temps/gauges
No problem....I've done one thing right today I guess!
Some where in this forum someone posted a cheat sheet that detailed all the settings in a flow down chart but I would be hard pressed to remember where its at or who did it.
Wow! again I am amazed at the computer technology on the C-7's...I would love to have this as my default screen...I currently have the curve which displays safe rpms while the car warms up..with the yellow line atop the curve such and so forth...with most of it displayed in the heads up aside from the caution line for warm up...but I never knew that all of this info could be displayed at the same time! Gonna check his out! Thanks for the post....
I like this display view, ill be checking it out after work today. Thanks!
