Issue with 2nd gear
Old Feb 16, 2020 | 11:54 AM
GaToy's Avatar
GaToy
Default Issue with 2nd gear
I have a 2014 Z51 M7 with 19K on it. Every now and then when I shift from it won't engage. I have to push back forward a little and then it will pull into gear. Could I have a faulty shift lever linkage or do you think the problem could be inside the transmission such as a synchronizer?
Old Feb 16, 2020 | 11:57 AM
Maxpowers's Avatar
Maxpowers
There is a procedure to adjust the linkage. I would start with that.
Old Feb 16, 2020 | 07:34 PM
The Successful Plumber's Avatar
If you’re shifting from 1st to 2nd it might just be the skip shift, which is normal.
Old Feb 16, 2020 | 09:32 PM
GaToy's Avatar
GaToy
It only happens when i'm shifting from first to second occasionally. It doesn't scratch. It just stops mid shift.
Old Feb 16, 2020 | 09:48 PM
Elk's Avatar
Elk
This description does sound like the skip-shift function working as it is designed to do.
Old Feb 16, 2020 | 11:14 PM
GaToy's Avatar
GaToy
I'm going to have to do some research on this quick shift as I am not familiar with it.
Old Feb 16, 2020 | 11:19 PM
FX VETTE's Avatar
FX VETTE
google this: CAGS Skip Shift Eliminator for 2014-2019 Corvette
Super cheap and easy to install if you have the means to get under your car. I had the same problem with 1st to 2nd occasionally, not anymore though.
Old Feb 16, 2020 | 11:23 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Skip shift, not quick shift.
Old Feb 16, 2020 | 11:25 PM
jaywoo's Avatar
jaywoo
It happens when you are below 19mph and the car is warmed up. It locks out 2nd gear and wants you to skip to 4th. Hence, skip shift. Another way to get rid of it is if you happen to have HP Tuners. Easy to disable with that.
Old Feb 16, 2020 | 11:28 PM
rfh928's Avatar
rfh928
The skip shift override was the first thing that I installed on my C5 M6 years ago, and same with my M7 when I got it last fall. My indie mechanic installed it for 30 bucks labour...best investment you'll every make, believe me!
Old Feb 16, 2020 | 11:39 PM
You don’t need a skip shift eliminator, just stop short shifting it when going from 1st to 2nd. It will be funnier to drive too! Spin 1st gear up to at least 3500 rpm before grabbing 2nd.
Old Feb 16, 2020 | 11:40 PM
Zjoe6's Avatar
Zjoe6
Yep, so easy to skip the skip shift by just reving a little higher.
Old Feb 17, 2020 | 09:52 AM
GaToy's Avatar
GaToy
A lot of the time when it happens, i'm in town and driving in traffic.
Old Feb 17, 2020 | 10:01 AM
boss2k's Avatar
boss2k
In that case just put it to 2nd immediately or just rev a bit and put to 2nd, its easy to skip that stuff. Did you notice you get a message about 1-4 skip shift when that happens
Old Feb 17, 2020 | 11:14 AM
Just leave it in 1st, don’t short shift it. The skip shift engages when you try to shift from 1st to 2nd at a low speed or rpm.
Old Feb 17, 2020 | 02:48 PM
JMII's Avatar
JMII
Same thing happened to me under those conditions. So I got the CAGS and no more problems. Super easy to install if you are comfortable putting your car on jack stands or ramps.
When it happens a message should appear in the HUD and/or DIC. If you don't have the HUD the message may be so brief you don't see it.
If I wanted a car that told me when to shift I would have gotten an automatic!
Old Feb 18, 2020 | 12:28 AM
GaToy's Avatar
GaToy
I've seen a message pop up on the cluster. But that's the problem with riding in bumper to bumper traffic, by the time I look down is half a second before it disappeared. I've never been able to read it before it was gone. I have a four post lift so getting under the car isn't difficult. Looks like it will be my first mod.
To Issue with 2nd gear
