i have a 2017 z06. wondering if any one has made a hole from the engine compartment thru the firewall to the inside of the car. Im looking to run a wire from the fuse box to the inside of the car. Trying to find if someone has made a hole and where they did it at.
I have successfully run video and power wiring for a front camera from the engine bay to the inside by running it through a space on the driver’s side door hinge below the “A” pillar. Perhaps that would work for you.
My SiriusXM antenna died and while checking different locations for an aftermarket unit I ran a wire the same way. There is plenty of room and you can get the wire under the weather stripping to ensure no water leaks into the car.
