Competition seats interchangeable?
Old Feb 25, 2020 | 11:01 PM
Brandon Medina's Avatar
Brandon Medina
Default Competition seats interchangeable?
Question:
For some odd reason I remember seeing that the earlier year seats were different (wire harness?) than the later years? I have a ‘15 looking at buying ‘19 Comp seats. Will there be any issues??
Old Feb 25, 2020 | 11:26 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by Brandon Medina
Question:
Why not just convert the seats you have Vs purchasing whole new seats? You only need to convert the seat back. Purchase the comp seat back skin, comp seat seat back foam and the plastic parts that provide the shoulder belt path throughs and put them on your current seats. The seat frames are the same for both types of seats. The difference between the seat bottoms is nill. The comp seat may have stiffer seat bottom foam and the GT seat has one less seam in the seat bottom skin.
Here is the link to a package you can purchase that provides everything you need to do the conversion: https://www.trunkmonkeyparts.com/p-c...ts-compseatkit
Bill
Old Feb 26, 2020 | 02:53 PM
ersatz928's Avatar
ersatz928
The difference is between 1LT Comp seats and 2LT/3LT Comp seats. 1LT has no seat heaters, position memory, ventilation fans, or inflatable lumbar support.
Old Feb 26, 2020 | 03:29 PM
96GS#007's Avatar
96GS#007
The connector under the seat that connects the seat wire harness to the car harness is different. Different shape and pinout. As I recall, the seats use a different approach to determining position...which affects airbag deployment...and the seat belt switch works differently.
Bottom line....electrically they are not a bolt in.
To Competition seats interchangeable?
