‘19 fails emissions
Old Mar 9, 2020 | 01:20 PM
weathermaker's Avatar
weathermaker
Default ‘19 fails emissions
Took our ‘19 GS Vert A8 3800 miles,in for a sticker at local facility. Emissions failed. As soon as machine was plugged into the OBD port, the CEL comes on and automatically fails car. Multiple codes. P0700, U0100, U01010. I had the triple flush done in the fall and then put car away for the Winter. Drove around for at least 300 miles in the last week. I can’t believe the flush had anything to do with it. P0700 is transmission control problem I think. Made appointment with dealer for Wednesday. We will see what they find.
Old Mar 9, 2020 | 01:22 PM
slburgie's Avatar
slburgie
Before running it through the tester, drive it hard and burn them cats. That helps sometimes.
Old Mar 9, 2020 | 01:28 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Isn't 100 code a faulty PCM? I would be going to dealer.. that is a lot of codes . Why is a 19' getting tested already?
Old Mar 9, 2020 | 03:44 PM
weathermaker
In MA every car gets tested weather new or used. When I got the car in March 2019, the a-holes jacked the car up and checked the ball joints. I said the car has only 100 miles on it. He says the Registry has cameras and watches us. Dipshits. Today I took it to a different shop and they jacked it up and checked ball joints. Car has 3800 miles. I ran the car around town and on the highway for over a 3/4 of an hour. Fully warmed up and was ready to be checked. The car is running fine and shifting normal. We’ll have to see what dealer had to say. Have been driving it all day. 70* here today.
Old Mar 9, 2020 | 04:17 PM
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
Do you have the range device plugged in ?
Old Mar 9, 2020 | 04:18 PM
TXSteveF's Avatar
TXSteveF
If you have a Range ensure it's unplugged for a few weeks prior.
TXSteveF's Avatar
TXSteveF
You beat me by one minute...
Old Mar 9, 2020 | 04:53 PM
Avanti's Avatar
Avanti
Not uncommon and no shortage of threads on this if one does an "Advanced Search" in C7sections.
Old Mar 9, 2020 | 05:06 PM
Tommy79's Avatar
Tommy79
It's under warranty... Take it to the dealership... Problem solved.
The "Range" group says it causes no issues... But they ALL tell you to remove it before taking it to the dealership.... Play it safe and remove that puppy.
Old Mar 9, 2020 | 05:42 PM
weathermaker
No Range device. Going in on Wednesday.
Old Mar 10, 2020 | 05:06 PM
weathermaker
So I drove the car yesterday and today for about 150 miles. The garage had cleared the codes yesterday before I left. I went back and the car passed emissions. I don’t know what happened yesterday when the car was connected to the test machine. The CEL came on and car failed. So I’ll worry about it next year.
Old Mar 10, 2020 | 05:12 PM
Elk's Avatar
Elk
Great news!
I bet it was an odd little fluke.
Foosh's Avatar
Foosh
All vehicles will "fail" emissions testing with a CEL illuminated, and won't pass after codes are cleared until the car is driven 100 or so miles with no new codes. I've seen this several times on vehicles over the last decade or so.
To ‘19 fails emissions
