Break squeal
If most of your driving is around town with lower speeds and light braking, the brake pads could be glazed. Take it out to a nice country road, get up to 45-50 mph and brake hard. Do that a couple of times and see if the rear brakes still squeal.
Do you drive on any gravel roads? Could be a small rock stuck in a brake caliper.
Yep performance brakes need to be used aggressively from time so there is not an irregular build-up of pad materials on the rotors. It's very thin, NOT something you would see. It causes slip-stick friction, vibration and squeal.
My experience with my 2014 Z51 having babied the brakes was at ~1000 miles had a slow speed stop squeal like a stuck pig! Bedded the pads using a procedure outlined in the Owner's Manual for Tracking. GM calls it burnishing! NOT their suggested 25 stop procedure, 5 or 6 should do it. As they note, don't go to zero speed. Stop hard from ~60 mph, as you note, to about 15 mph. Key is to find a safe space. My squeal was gone.
Look at the Owner's Manual and follow what they say BUT for 5 or 6 times NOT 25! If it doesn't go way some dealers were putting lub on the pad edges. Some report it helps for a while. But dealers get paid nothing for Bedding! In fact they won't drive your car to do it! But on warranty they get paid by GM to put lub on the pad edges!
