Battery question
Old Mar 20, 2020 | 11:15 AM
Apocolips's Avatar
Apocolips
Default Battery question
Maybe a stupid question, but when I was younger I was told that while charging a lead acid battery it would put off gases while charging. Now I understand that battery technology has advanced but is this still true? I have a battery tender attached to the car and want to put the cover on it as well. Will the cover trap any gases under the cover and harm the paint or any other components?
Old Mar 20, 2020 | 11:25 AM
Maxpowers's Avatar
Maxpowers
Youre safe to put the cover on. Modern battery maintainers dont charge to the extent that there is extensive gassing. I switched to an AGM battery which vents less (if any).
Old Mar 20, 2020 | 11:36 AM
Flame Red's Avatar
Flame Red
The C7 battery actually has a small hose connected to it that moves whatever gases are generated outside. Well, unless you changed the battery and did not hook up that original little hose.
Old Mar 20, 2020 | 11:54 AM
SilverGhost's Avatar
SilverGhost
The following is from Gerald Uttrachi, a fantastic writer of how-too articles for the C7. Sadly he has moved on ....to the C8
AGM batteries do vent! Quoting from a marine source- they should know: “Even though AGM batteries are normally sealed, they do have a venting system integrated into the case top. In the event of an overcharge condition, it is possible for pressure to build up inside the battery and then release after a 2 or 3 psi accumulation. If it occurs, hydrogen gas will vent and it is quite explosive.” The Diehard comes with holes on both sides of the battery top. The ( C7) OEM battery has a hose that exits out the bottom of the car. The 90-degree plastic hose fitting on the OEM battery fit the Diehard as did the OEM plug that fit the other hole on the Diehard. The 90-degree angle elbow fitting was placed on the hose that comes from the C7 battery well floor. It was tucked under the right-side carpet to clear the new battery during the install. After the battery install it was placed in the right-side vent hole by “feel” as there is little room to get your hand in and no visibility
http://netwelding.com/Battery_Issues.pdf
i learned from my c6 that if you keep a trickle, even with microprocessor monitoring, battery tender constantly on for 7 years, you will gas out all the water, ruining the battery. DO slice the label covers over the "caps" and remove them periodically to check to see water is still over the plates.
Old Mar 20, 2020 | 12:15 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
On our C5 and first C6, we drove the cars enough even during winter, that we never used a charger or tender. But each year I would remove caps when battery was fully charged, and check. Always needed to add a bit of distilled water. So I'm not sure if a proper tender that cycles only when needed, is any worse than just driving the car.
Old Mar 20, 2020 | 12:31 PM
solteroblues's Avatar
solteroblues
yes, it is true that all batteries, no matter what type, even sealed cell batteries still off gas a small amount. But putting the cover on shouldn't really be a big deal. It still breathes to an extent.
Old Mar 20, 2020 | 01:08 PM
Rayland's Avatar
Rayland
Banned Scam/Spammer
Apocolips;
During charging, (especially in the event of over charging), lead acid batteries produce oxygen and hydrogen. These gases are produced by the electrolysis of water from the aqueous solution of sulfuric acid. Since the water is lost, the electrolyte can be depleted. This is why you need to add water to non-sealed lead acid batteries.
Note: When a lead acid battery cell "blows" or becomes incapable of being charged properly, the amount hydrogen produced can increase catastrophically.
Aqueous def: is a solution in which the solvent is water. Mostly shown in chemical equations.
Many thanks,
Ray
Old Mar 20, 2020 | 02:34 PM
NoRuls's Avatar
NoRuls
I'm having Paul Koerner install a new battery in my 2016 Stingray Z51 and asked his advice as to which DELCO battery would be best for me. I asked about either an AGM one or one of three 48 series all DELCOS. He said absolutely DO NOT use an AGM type because the computer is NOT programmed for that type and COULD do damage to the computer and also the alternator. Chances are you all know who Paul is and fortunately for me he does all the maintenance on my car. If Paul says it I believe it. BTW his recommendation for me was the DELCO 48PGHR. Ron
Old Mar 20, 2020 | 03:25 PM
joemessman's Avatar
joemessman
Paul is great! I used to listen to his Corvette podcast, which is no longer on. But when I took a trip in my Stingray three years ago I made a point to stop in and say hello to him. He bought me lunch.
There is no technician more knowledgeable about Corvettes I have been told.
Old Mar 20, 2020 | 03:35 PM
CraigStu's Avatar
CraigStu
Did he elaborate any more on that? 'The computer is not programmed for that type....' Which computer and how does it's programming affect the battery? As far as I know alternators have built-in regulators that control their charging process.
Old Mar 20, 2020 | 04:30 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Thanks. This is a pic from my PDF showing the vent hose:
Old Mar 20, 2020 | 06:58 PM
Maxpowers's Avatar
Maxpowers
I looked up Pauls credentials and he is well respected. Having said that, i dont think a master GM tech would ever reccomend a non OEM part as part of their job. For passenger vehicles, AGM batteries have way more pros than cons. I suspect GM doesnt use them because they cost more. They were even too cheap to put a handle on the OEM delco. I havent read one case of an AGM battery causing damage in the C7. Folks are even using Lithium now.
Old Mar 21, 2020 | 10:50 AM
NoRuls's Avatar
NoRuls
Not to start a pi$$ing contest here but Paul will install aftermarket parts if he feels they are a quality product. When I had my 2006 Z51 Vette I had the dreaded harmonic balancer issue and he recommended the Summit balancer which he installed for me. The DELCO AGM I was considering is $26 more than the DELCO 48PGHR so I don't think that's much of a difference or deal breaker on a $60-110,000 vehicle. In my OP Paul said damage COULD happen so if you haven't found any evidence of damage happening that's great. For me, why take the risk? When I hopefully see Paul next week I'll check into any further info on the reasoning behind the computer question. Ron
Old Mar 21, 2020 | 11:10 AM
JerryU's Avatar
JerryU
In my OP Paul said damage COULD happen so if you haven't found any evidence of damage happening that's great. For me, why take the risk? Ron
Hmm, what risk? Have had an Optima Yellow Top AGM in my Street Rod for 20 years. Only 2nd one! Had a Optima Yellow Top in my C6 Corvette (since the car was yellow, picked that color!) The Diehard AMG I put in my 2014 Z51 worked just fine!
Now less expensive, more conventional stacked plate AGM batteries are available (as is the unique cylindrical wrapped "plates" in the Optima design; bought my Johnson Controls some years ago.) Johnson Controls battery group (now owned by Canadian company Clarios) and a few others make them for many brands. Toured their plant and reclamation faculties in our town. At the end of the manufacturing production line folks put on one of ~20 Brand labels!
Old Mar 21, 2020 | 12:48 PM
Maxpowers's Avatar
Maxpowers
Not at all, and i didnt mean my comment to come across that way if it did. Just trying to gather more facts on AGM batteries in our rides. Share any info you can if you connect with him.
To Battery question
