Little Quickjack tweak--$10
Old Apr 18, 2020 | 01:01 PM
JonMN's Avatar
JonMN
Default Little Quickjack tweak--$10
OK, covid boredom might be setting in, but I am doing my best to keep Amazon afloat. I like my Quickjack, but placing the blocks before lifting is kind of a pain just due to visibility. I found these very little battery LEDs, $10 for a set of 6, on Amazon (
LINK LINK
). They attach via tape and have a simple on-off switch to save the battery.
I stuck on on the side of each block. I had hoped to set them on the top, but they are a little too big. Worked great! What I would really like to do is drill a hole thru the center of the rubber block and mount a LED dead-center, but that might be next year.
Old Apr 18, 2020 | 01:15 PM
1999PewterCorvette's Avatar
1999PewterCorvette
Excellent idea !!!!
i just ordered a set.
Old Apr 18, 2020 | 01:17 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
I like your idea! Adding to my "Amazon Bored Buying" list.
Old Apr 18, 2020 | 01:24 PM
Jeff V.'s Avatar
Jeff V.
Nice! I'm going to have to get a set of those.
Old Apr 18, 2020 | 02:18 PM
1999PewterCorvette
Is the light on the side?
drilling a hole in the center sounded good but it doesn’t look like the orientation of the light would make it work.
Old Apr 18, 2020 | 02:44 PM
JonMN's Avatar
JonMN
A hole in the center would be better for sure, but this lit up the area enough to help. Tried them on the top, but not quite enough room.
Old Apr 18, 2020 | 10:29 PM
They look like they could be really handy. Are they as bright as they claim to be?
Old Apr 18, 2020 | 10:38 PM
JonMN's Avatar
JonMN
^^^ I was surprised how bright they were. Not sure they could light up a closet like it shows in the packaging, however. (PS: Next time I might try moving them to the long-side of the rubber block instead of the short end.)
Old Apr 19, 2020 | 05:11 PM
Cman01's Avatar
Cman01
HHHmmmm, I wonder if these "little" button lights throw enough light on the dash sensor so if you start the car in the garage it will keep the headlights from coming on or before you drive your car back into the garage after a drive again keep the hdlts off till you shut off the car.
The auto hdlts come on way too early and I'm trying to find a permanent way around that, if these lights will do the trick temporarily I can keep the lights off while I figure out the proper solution.
Tony
Old Apr 20, 2020 | 09:59 PM
Jaykoh-Z51's Avatar
Jaykoh-Z51
Jon, my Quickjack is currently enroute to me. . I haven't personally seen one yet.
Pardon my ignorance here...are you using the lights to help align the blocks to your jack pucks? Or just for some extra illumination under the car?
Thank you sir.
Old Apr 20, 2020 | 10:08 PM
JonMN's Avatar
JonMN
^^^ hope you like it! This was just to help align the blocks. Of course you can use a small flashlight instead. I still want to come up with a LED in the center of the block. This would be ideal.
Old Apr 21, 2020 | 08:50 AM
Dennis Bernal's Avatar
Dennis Bernal
Great idea!
I put the rubber block close, then for final fine tuning make sure the puck hit the back of my four fingers, and the block is centered on the same.
Finally, I go pump the jack up just enough to have the pucks make contact, then do one last check to ensure it is all centered. Always is.
Then up she goes!
If it is just for centering ease, maybe a pocket laser pointer would work. Drill a hole in the center and easy to turn on and off with a rear switch.
Just an idea. Less all around illumination of course.
To Little Quickjack tweak--$10
