C7 auto unlock
Old Apr 29, 2020 | 11:19 AM
ericstanley's Avatar
ericstanley
Default C7 auto unlock
2017 GS. Since new, the doors have always unlocked automatically when i approach the car. A couple months ago there were a few times that I had to use the remote to unlock it when I first drive it the morning, but then it would work fine all day after that. More recently, this problem has progressed to the remote not working at all unless I use the actual key to pop the trunk, then suddenly the remote works fine... unless I let the car sit for several hours / overnight. Examples:
Morning: have to use the key to pop the trunk (sets off the alarm), then unlock the doors with the remote, then drive away. Stop at a store, go in for a bit, come back out and it works fine (auto unlock and everything). Go back home. Let it sit a few hours.
Evening: have to use the remote to unlock the doors. Short trip to the store, and it works fine again.
Overnight: car sits in the garage
Morning 2: have to use the key to pop the trunk and can repeat the previous steps.
Thoughts?
Old Apr 29, 2020 | 11:31 AM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
I also have a '17 GS, and was having intermittent issues with my fob. Once I replaced the battery that came with the fob, all issues were in the past. Worth a shot if your fob is still with the original battery. Whatever the fix ends up to be, let us know how you make out. Good luck.
Old Apr 29, 2020 | 11:37 AM
ericstanley
Considered changing the battery, as well, and will do to rule it out.
Old Apr 29, 2020 | 11:38 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
By auto-unlocked automatically, do you mean when you touch the door pad to get into the car, it unlocked?
Change the FOB battery in both of your FOBs.
Elmer
Old Apr 29, 2020 | 12:02 PM
Tin-can's Avatar
Tin-can
I look forward to hearing if changing the fob batteries solves your problem. Good luck!
Old Apr 29, 2020 | 12:03 PM
orca1946's Avatar
orca1946
Like unplugging your computer, changing fob batteries is the 1st step I do.
Old Apr 29, 2020 | 12:30 PM
Maxpowers's Avatar
Maxpowers
Its the battery. Also, the doors wont unlock when you approach the car, it does when you press the door release button.
To C7 auto unlock
