Curious if anyone has the same experience. I like to set my lumbar support out a bit. After a few weeks it resets back to zero. Maybe its a leak in the bladder?
It doesnt bother me enough to rip the seat apart but thought there may be an easy fix. I dont believe lumbar associates with seat memory function. Thx...
My '14 lumbar gave out about 2 years ago. Now it deflates in about an hour. If anyone has a quick fix pls let us know.
A few years ago I took out the drivers seat, took off the bottom seat cover to trim down the foam to make it more comfortable. It wasn't terribly difficult - there is at least one post on doing it. You don't need any special tools, just time and patience and taking off the targa top. That being said, I don't recall how difficult the covering on the seat back would be to take on and off and the way the lumbar system works.
If someone wanted to I suppose you might be able to switch the lumbar mechanism from the passenger side, but not the seat back itself due to the air bags.
My lumbar/side bolster support always lost pressure over the space of a few hours. However, I took the car on a 3 hour one way trip last year and noticed I had to pump up the lumbar support several times during the three hours. GMEPP covered the repair which was $583.00.
