Changing diff fluid question
Old May 5, 2020 | 05:19 PM
Red08's Avatar
Red08
Default Changing diff fluid question
After changing my diff fluid, is it still recommended to do a bunch of figure 8's? That was the recommendation on my C6.
Old May 5, 2020 | 06:37 PM
Pablotheartist's Avatar
Pablotheartist
Im about to do mine this weekend so I am curious as well what the procedure is.
Old May 5, 2020 | 08:07 PM
rfh928's Avatar
rfh928
My mechanic always advised me to do the figure 8's on my C3 and C5...so have to think that the concept is similar. I've only had my C7 since the fall, so will be a while before I have to do this.
Old May 5, 2020 | 08:10 PM
L82Brake's Avatar
L82Brake
You are supposed to run it and then re-check the fluid level. Lots of threads and youtube videos. Do a search.
Old May 5, 2020 | 09:58 PM
ersatz928's Avatar
ersatz928
Figure 8s is only for mechanical limited slip diffs, to break - in the lockup clutches with the new gear oil, so they dont chatter.
No need for this on the C7.
Old May 5, 2020 | 10:30 PM
Kracka's Avatar
Kracka
50k miles and 2 diff fluid changes performed so far... I've never wasted the time doing the figure-8's. The differential has taken the proper quantity to fill both times and hasn't had a change in performance after either job. The initial factory-fill was pretty nasty when drained @ 22k miles though; so was the transmission (M7).
Old May 6, 2020 | 12:37 AM
rfh928's Avatar
rfh928
I think my base Stingray has a mechanical LSD...isn't the e-LSD an upgrade? Is the base LSD on the C7 different from older generations?
Old May 6, 2020 | 07:20 AM
shakinrock's Avatar
shakinrock
Is the differential fluid change done strictly on millage or does age also necessitate its replacement?
Old May 6, 2020 | 08:09 AM
mityaz's Avatar
mityaz
In eLSD the clutch plates are bathed in a different fluid compartment that does not get drained during diff oil change. No need to break apart the clutch plates. No need for figure 8s.
Old May 6, 2020 | 09:29 AM
Litfuse's Avatar
Litfuse
Most manufactures suggest replacement on a basis of age and mileage. Most non performance cars are around four year/50k miles. However, more European manufactures are claiming there is lifetime fluid in their differentials. I am hesitant to believe that. On a performance car, or a car you care about for that matter, I suggest draining your rear diff fluid early, around 4K miles. A friend of mine build custom diffs for highly modified 4x4s and he suggests the first diff drain at 500 miles to remove all the shavings.
Old May 6, 2020 | 10:00 AM
RonC7's Avatar
RonC7
Yes, base C7 is a limited slip differential with mechanical clutches.
Old May 6, 2020 | 10:02 AM
Internets_Ninja's Avatar
Internets_Ninja
According to the service manual you are supposed to leave the car raised off the ground, turn off traction control, and accelerate to 10mph and hold for 1 minute. Then check/top off the fluid and then you are done.
Old May 6, 2020 | 11:03 AM
orca1946's Avatar
orca1946
I guess that is to move the fluid into all the nucks and crannies
Old May 6, 2020 | 11:29 AM
JMII's Avatar
JMII
The manual states mileage unless tracking the car then age becomes the factor.
Old May 6, 2020 | 11:34 AM
Jerrymannal's Avatar
Jerrymannal
Yesterday I had my oil changed and new battery installed in my 2016 Z51 m7 at a local Chevy dealer. I also them how much to change the transmission fluid and when they quoted $363.00 I declined. My trans shifts ok, a little notchy, but ok. So my question is —is it really a big deal to flush the M7 hydraulic fluid, is there a fluid upgrade, and what’s a fair price?
Old May 6, 2020 | 11:41 AM
Internets_Ninja
To make sure fluid is in the differential cooler and lines.
That is a bit high. You can do it yourself if you have the tools. The GM OEM fluid is the best to use and will be about $75 worth of fluid.
Old May 6, 2020 | 07:27 PM
George_L's Avatar
George_L
I did the recommended minute or two of letting the car run at about 10 mph then rechecking the fluid. Mine did not take any additional fluid. I won't bother with that step next time. Mine is a 2014 Z51.
Old May 6, 2020 | 09:14 PM
Bill Dearborn's Avatar
Bill Dearborn
OM states 45K followed by intervals of 45K miles for street and highway driving. That recommendation is for both normal and severe service.
However, OM also states in the Track Section the Diff Fluid needs to be changed after the very first Track session and then every 24 hours of track usage after that.
Bill
Old May 6, 2020 | 10:17 PM
George_L's Avatar
George_L
I changed mine at 5,000 miles and it looked bad. It had a very silver, shimmery (if that's a word) look to it and also very dark. Most people report the same. It would probably have gone 45,000 miles without a problem but I'm very glad I changed it. Cheap insurance (about an hour of time and the cost of the fluid).
To Changing diff fluid question
