NPP exhaust
Old May 9, 2020 | 06:18 PM
Papas Vett's Avatar
Papas Vett
1st Gear
Default NPP exhaust
I just purchased my first Corvette and I am loving it. All except for that it does not have NPP exhaust. My question is if I purchase a new exhaust with NPP is the 2018 Corvette prewired for NPP exhaust?
Old May 9, 2020 | 06:23 PM
Jmhornz71's Avatar
Jmhornz71
You might want to consider an aftermarket system and not have to worry about the parts for npp not being there
Old May 9, 2020 | 06:35 PM
TOSOC7's Avatar
TOSOC7
I replaced the stock exhaust with the Corsa Xtreme and couldn't be happier. I had the NPP exhaust on a previous Corvette and much prefer the Corsa...great exhaust sound and zero drone.
Old May 9, 2020 | 06:46 PM
sTz's Avatar
sTz
My Z06 was equipped w/NPP. I swapped out the exhaust with the Corsa Extreme (non-variable sound version) and their X-pipe, and never looked back. You can easily control the volume with the pedal.
Old May 9, 2020 | 06:48 PM
teghogh's Avatar
teghogh
Default Npp
Purchase npp take offs and have a muffler shop weld them in. You don’t need the npp functionality
Old May 10, 2020 | 10:26 AM
Maxpowers's Avatar
Maxpowers
If your car didnt come with NPP, then its not wired for it and the module is not programmed for it.
Old May 11, 2020 | 06:32 AM
bill K's Avatar
bill K
I purchased an NPP exhaust from a forum member and 2.5" electric cut outs. I had my muffler shop remove original valves and install cutouts. Now I can open and close valves from a remote or my home link. This cost me less than $475.00 done. These look and work great.
Old May 22, 2020 | 07:30 PM
bbrown450's Avatar
bbrown450
My man, sorry to hear about the GS not working out. I know that you are new to the forum so just to be clear theIr are (2) levels /Types of exhaust Standard and Dual Mode or NPP ( RPO order code). The Regular exhaust comes standard but the GS and Z51 package it comes as part of those packages.
When it comes to aftermarket they all have their own sounds as was earlier referred to and you can hear them at the respective manufacturers websites. It is personal preference. If you have the NPP dual mode you can now get after market systems that retain that dual mode capability, otherwise you will lose that capability if you opt for a single mode exhaust.
You can also have an “X” pipe installed ( they have been now deemed to be used as “off road” and are not as prevalent but you can still find them for sale). This pipe replaces an existing OEM pipe that has a secondary set of C.Convertors (which creates more flow) and combines and distributes exhaust gases more efficiently and as a residual is louder, which makes anything you bolt on, including standard mufflers ...louder..
Hope this helps
Old May 22, 2020 | 11:20 PM
claf's Avatar
claf
NPP is grossly overrated. I have it and wished I didn't.
Old May 23, 2020 | 10:20 AM
Everyone has different tastes. I have the NPP system in my car and love it. Sounds great when fully open and has saved me the expense of having to purchase an aftermarket system for the car.
I’m sure there is a great aftermarket system out there that would be more to your liking. Corsa and Borka are two popular systems to consider.
Old May 23, 2020 | 12:29 PM
62RPO582's Avatar
62RPO582
Here's an aftermarket system that offers the dual-mode ability to control the sound like the NPP does. It is vacuum operated rather then electronic like the NPP, but allows you to control the sound level from loud to normal.https://www.corvettepartsandaccessor...ingray-non-npp
Old May 23, 2020 | 09:22 PM
rb185afm's Avatar
rb185afm
AWE touring with Borla X pipe is the cheapest way to equal audio nirvana.
Old May 24, 2020 | 01:04 PM
BLACKCREEK's Avatar
BLACKCREEK
I bought a set of npp mufflers and installed them along with the akrapovic npp controller. Everything is plug and play if you get a used set of npp mufflers that include the actuators also. Works just like factory on my 2015. The controller is around 550 and I got the mufflers locally on Craigslist for 250 including the npp valve actuators. The hardest part is removing the rear valence otherwise it is just unbolt one muffler and bolt in the other. The akrapovic controller is a can bus sniffer that goes in the rear electronics compartment. The software is already in the car you just need the harness to get it the rest of the way to the actuators. Look up under you car to see if you have afm valves installed forward of the mufflers, if you do then you need to buy a npp exhaust that has them also or cut off and weld in your valves. Install instructions are on the akrapovic website.
Old May 24, 2020 | 02:53 PM
bill K's Avatar
bill K
I installed my NPP with a cut out 2.5 flat cut out. Cost $99.00 on ebay and paid $225.00 for c7 exhaust. I had my muffler guy cut and install the cut out $140. Now I use my Home link or remote to open a little or a lot as needed. Much cheaper then a $1600 after market exhaust. I think it sounds Great.
Old May 24, 2020 | 03:06 PM
ChiefBoats's Avatar
ChiefBoats
T2T SUPPORTER
Veteran: Coast Guard
From: NNCC No Name Car Crew; Owned 1 C2, 2 C3's, 1 C4, 3 C5's, 1 C6, 2 C7's; Now '86, '03; S. DE
2023 C3 of the Year Wnner - Unmodified
St. Jude Donor '21-'22-'23-'24-'25-'26
Oh I don't think so, it's there for a reason....choice.
I achieved the perfect sound to my satisfaction by pulling the fuse for the NPP valves (keeps them open all the time), installed a Borla X-pipe, and a Range AFM disabler. Very happy with that setup.
Old Jun 2, 2020 | 09:45 AM
Full Send Media's Avatar
Full Send Media
3rd Gear
Im looking to do the same thing, could you send me some exhaust clips?
Old Jun 2, 2020 | 01:47 PM
bnkvette's Avatar
bnkvette
Veteran: Marine Corps
When I purchased my 15' vert it did not have NNP. I purchased a Corsa Sport muffler system from Chip at CCA and I am extremely satisfied with the sound, Zero Drone.
To NPP exhaust
Old Jun 2, 2020 | 01:53 PM
YO-EL's Avatar
YO-EL
I can sell you the Corsa Sport mufflers for CHEAP!~
Old Jun 2, 2020 | 03:56 PM
JMII's Avatar
JMII
Really? Almost everyone here wants the NPP sound and functionality.
I can't think of a downside to the system unless you don't like the look of the four chrome trumpets or its not loud enough.
Old Jun 2, 2020 | 04:08 PM
Rky Mtn C6's Avatar
Rky Mtn C6
2024 C8 of the Year Winner - Unmodified
2023 C7 of the Year Winner - Unmodified
In 2014 I bought a C6 GS with stock non-NPP exhaust. Immediately installed a Corsa Sport system with X pipe. Loved it. Got many compliments on the sound. In January I took delivery of a 19 GS with NPP. Learned I could select my own exhaust tone, and pull the fuse to keep the valves open all the time. Thought I'd give it a try and hopefully save some money. Well, the NPP is coming off, and a Corsa Extreme system with X pipe is going on.
