Cold start issue
Old May 12, 2020 | 09:50 AM
hgrant's Avatar
hgrant
Default Cold start issue
I'm having a cold start issue with my 2017 Z06 m7. My car would always start at approx. 1200 rpm .. stay there for 20 seconds or more and then drop down to 1000 rpm and stay there for a good 45 seconds or more .. and then drop to around 800 rpm for a while and then a final drop to around 650 rpm(normal idle).
The first couple times taking it out this season it is starting at 1000 rpm and dropping within 10 seconds down to 800 rpm and then pretty quickly down to 650 rpm. This happened on Sunday when it was only 50 degrees in my garage. You can hear that the motor is not really happy at such a low rpm while still being cold.
Otherwise the car runs great and I'm having no other issues.
Has anyone else experienced anything similar and if so what was the remedy to the issue? I have an appointment next week at my local dealer.
Thanks for any feed back!!
Old May 12, 2020 | 10:44 AM
laserdude2215's Avatar
laserdude2215
Your second scenario seems about the same as mine, but my motor is happy with it.
Old May 12, 2020 | 10:51 AM
saleen556's Avatar
saleen556
Sounds normal to me. Just depends on temps. The LT4 has a choppy idle anyway. Unless you have a check engine light I wouldn’t worry about it. 650 RPM is a normal idle.
Old May 12, 2020 | 11:16 AM
NSC5's Avatar
NSC5
Very normal, the advanced "idle" speed along with a rich fuel mixture and retarded timing is about getting the cats hot in a hurry in order to meet EPA cold start emissions standards and not about having the engine running smoothly. The maximum cold start idle speed and the time it spends in each step is dependent upon engine and air temperature.
And as others noted, the LT4 isn't noted for a smooth idle. Surprisingly, my 2018 GMC Denali with its 6.6L turbo diesel has a smoother idle than either my 2016 Z06 or 2014 Cadillac ATS (3.6L).
Old Dec 30, 2025 | 01:08 AM
Miki001's Avatar
Miki001
1st Gear
Did you manage to solve the problem?
To Cold start issue
