Drivetrain noise
Old May 26, 2020 | 08:43 PM
dromuald's Avatar
dromuald
4th Gear
Default Drivetrain noise
I have a 2019 Stingray with a 7 speed manual. I took the car on a road trip this weekend and drove it through some curvy roads and the Cherohala skyway. Obviously I drove it a little aggressively but not abusive. On the drive home yesterday cruising on the interstate I started to detect a subtle noise. At first I thought it was another car but quickly realized it was coming from my car. If I slightly accelerated or decelerated the whine would go away. It was most prevalent at steady speed, and the pitch changed with the speed of the car. I noticed it in gears 4-7. Putting slight pressure on the clutch had no effect so I don't think it is a throw out bearing. The car now has about 3200 miles on it and it definitely did not make this noise prior to the road trip. I did install the double extreme sound proofing from exotic corvette immediately after I purchased it due to the road noise on the freeway. I am very impressed with the results, but a little disappointed with this new development. I haven't driven it since coming home so I don't know if it will get worse, if it is normal, or if it is something to be concerned about. Any ideas?
Old May 26, 2020 | 10:30 PM
LT4CMG's Avatar
LT4CMG
Belt tensioner is one possibility
Old May 26, 2020 | 10:47 PM
RCollier's Avatar
RCollier
Check both differential and transmission fluid levels.
To Drivetrain noise
