I have a broken bolt on my passenger side motor mount (nut sheared off from bottom side of carrier) Is this replaceable by itself or do I need to buy a whole new motor mount? How hard of a job is It to swap out motor mount?Any help is appreciated.
A8 17’ stingray
I have both if you are in need of them no used for them I went with the LG solid mounts in my car....But you do pay the shipping.. Robert
Thanks for the offer. I ordered a new mount from GM direct, I will reach out to you if something gets messed up with the order.
How difficult was it to remove factory mounts and install new ones? I’m looking for any advice or direction as to how this can be achieved . If it will be difficult I guess I can take it to shop for help.
I pulled my motor and did it when I did a forged motor. BUT ALL YOU NEED TO DO IS replace the broken one 1st BUT YOU NEED TO unbolt the good one per say as much as you can so it it let the motor lift some also but jack up the broken side so it goes up in the air but also angles over to the side that is good. Then bolt in that one but you need to do the same on the other side if you replace both of them. This is the way I did it on my c5 with the same mounts with the motor in the car..Robert
