PDR non-function
Old Jun 16, 2020 | 06:49 PM
Russkier's Avatar
Russkier
Default PDR non-function
My PDR says no disc inserted when there is one inside. I usually switch one out with another one when I get back from the track, but neither of them work. Any ideas?
Old Jun 16, 2020 | 07:10 PM
BAT's Avatar
BAT
2026 Corvette of the Year Finalist - Modified
2025 C7 of the Year Winner - Modified
2024 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year FinalistAX - Modified
Make sure the card isn't in the locked position.
Old Jun 16, 2020 | 07:32 PM
Russkier's Avatar
Russkier
You mean the little tab on the disc? isn't that what holds the disc in the adapter?
Old Jun 16, 2020 | 08:01 PM
Elk's Avatar
Elk
Old Jun 16, 2020 | 08:07 PM
Kehraus's Avatar
Kehraus
It has to be formatted properly too.
Old Jun 16, 2020 | 08:53 PM
RonC7's Avatar
RonC7
Format FAT32 is required for C7.
Old Jun 16, 2020 | 09:40 PM
BAT's Avatar
BAT
Originally Posted by Elk
I had switched mine to the locked position and got the same message. Once I "unlocked" the SD card, it was fine (just like the image above). Take a look at yours, could be what's causing your message too.
Old Jun 16, 2020 | 09:50 PM
geraldschumann's Avatar
geraldschumann
SanDisk is the only one that has worked best for me. Other brands can be iffy. Also check that it’s class10.
Old Jun 16, 2020 | 10:26 PM
Elk's Avatar
Elk
Given the OP indicates he uses two cards and swaps one for the other, I assume these cards previously worked and were formatted correctly. He is also using an adapter.
Thus I conclude the lock tab on the adapter is in the lock position and needs to be moved to the unlock position to solve the problem.
Now we need to hear from the OP to learn if this worked.
Old Jun 17, 2020 | 01:30 PM
Russkier's Avatar
Russkier
Elk, that was it ! I thought that that the tab just locked the disc into the adapter but I moved it up and now it works. Now all I need is a laptop so I can explore the programming in the disc. I believe that it will open up a new world.
Thanks again, Russ
Old Jun 17, 2020 | 02:57 PM
BAT's Avatar
BAT
Thanks again, Russ
Kidding aside, glad it was just that and it worked out.
To PDR non-function
