Dash cover recommendations
on another note, is it easy to remove the top vent cover? wonder if it just snaps in or if it’s screwed in from underneath.
When I hear dash cover all I can think of is the carpeted eye sore people put on cars in the 90s.
If 90% of the dash is ok, seems like overkill to cover it all just to hide the 10%. Maybe there is something creative that can just cover the problem areas, like a phone holder to radar detector... no idea.
Also never herd of or seen a dash pad cover for a C7.
If, however, the piece that is bad is the small section that trims the very edge of the instrument panel, and goes up the left side of the console and around the HUD cut out, that is easy to replace, and the part is available to order.
P.S. re-read the original post--if vent means the defroster slot, that's the big, main dash piece that is the big labor job to replace. And it will get worse--that's where mine started pulling away, this time.
Have you had a good upholstery shop look at it?
Search this forum, I remember a thread where a guy fixed his by injecting adhesive under the leather.
One option may be pull windshield for access
Dash Design, local to you in Tempe AZ, Sedona Suede or Dashtex material looks a bit better
Covercraft
Coverking, only company with speaker cut out option
They all have defroster and sensor cut out
You may need HUD cut out option
If you contact these company's they will send you samples
I got my front Windshield tinted inside, not dark at all, hard to tell its tinted, really knocks down heat, Llumar Formula One Stratos
Covercraft
just an idea for a relatively cheap way out..
