Spark plug fouling
Old Jun 29, 2020 | 06:24 PM
TJEvans224's Avatar
TJEvans224
Default Spark plug fouling
Good morning, for the second time I have had an issue with the engine idling very rough and very rough acceleration.
I took it to the dealer and they said my plugs are fouling and I need to drive it more.
It is a 2017 Grand Sport with about 12,000 miles.
I do drive it to Cars and Coffee about a 160 mile round trip every other week.
Has anyone heard of this before?
Thanks for your help.
Old Jun 29, 2020 | 06:28 PM
TJEvans224's Avatar
TJEvans224
The dealer said I need to change all the plugs for $375.00 Coly Cow !!
Old Jun 29, 2020 | 06:40 PM
lakemg's Avatar
lakemg
Did the issue start happening right after they changed the oil (assuming that they change the oil for you)? I'm wondering if they over filled your dry sump system and you've been pulling oil into the engine.
Maxpowers's Avatar
Maxpowers
Go to another dealer. Plugs on a 17 with 12K should be fine. If its the plugs, there is another issue that should be covered under the 5 year powertrain warranty.
Old Jun 29, 2020 | 06:59 PM
Dcasole's Avatar
Dcasole
Agreed
Dave
Old Jun 29, 2020 | 08:30 PM
Avanti's Avatar
Avanti
Plugs don't foul themselves... they (more than one?) are fouling WITH something, most likely oil. Note well the relevant response above. All the best.
Old Jun 30, 2020 | 07:33 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
Make sure you are using Top Tier fuel and at least 91 octane. 93 is preferable. It does sound like it could have been overfilled when the oil was changed. If the dealership did the oil change and there is oil in the intake system, this is their fault and they need to change your plugs for free.
Old Jun 30, 2020 | 07:51 AM
Dennis Bernal's Avatar
Dennis Bernal
Plugs don't fail by themselves, something kills them. With such a new car and so low miles I doubt its gas related. Highly suspicious of oil issues.
Take out an easy to reach plug. How does it look?
You need to do some investigation on your own. More data is needed.
Old Jun 30, 2020 | 09:25 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If oil ingestion is suspected, pull off the throttle body hose and shine a light into the intake. If you see oil, discuss the normalcy of oil in the intake manifold with the dealer. You can also take off the air baffle that sits at the front behind the radiator fan. If you've had an oil overfill, just take off the baffle and turn it upside down and see if oil drips out. Both those are good checks for an overfill of oil.
Elmer
Old Jun 30, 2020 | 04:44 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
In addition to "normal" over filling of the dry sump oil tank, I've been told that if the Tech uses a big funnel and dumps in a whole bunch of oil at once, it can't drain down into the tank quickly enough and some can end up in the line that leads to the air intake. So you can get the effects of over filled oil, even if it just shows normal level on the dipstick.
Fortunately, no personal knowledge here...
Old Jun 30, 2020 | 04:55 PM
Dcasole's Avatar
Dcasole
Agreed ..... this is absolutly not normal and the dealer trying to soak him for a new set of plugs is crazy and dishonest
No way its the valve seals because the car is to new so it has to be an overfill oil problem
Now it's only the dealerships problem if they did the last oil change
Dave
Old Jun 30, 2020 | 06:16 PM
TJEvans224's Avatar
TJEvans224
The dealer said they are carbon fouled, not oil, not running too rich ??
Old Jun 30, 2020 | 10:53 PM
Fouling of plugs with such low miles is not normal.
Old Jul 1, 2020 | 01:54 PM
jimmbbo's Avatar
jimmbbo
2019 OM, 2017 same info
Old Jul 1, 2020 | 01:57 PM
jimmbbo's Avatar
jimmbbo
If carbon fouled, a rich mixture is a likely culprit which will require more troubleshooting... Does the OBD show a code?
Old Jul 1, 2020 | 02:22 PM
Dcasole's Avatar
Dcasole
Then the dealer needs to check your injectors for leaks , known problem
Love when a dealer just shoots a parts cannon at a problem
Dave
Old Jul 1, 2020 | 02:25 PM
eboggs_jkvl
Moderator emeritus
Dave
Oh hell yes.
Elmer
To Spark plug fouling
