For those of you that have been to a shop with the Rear Caster tool (or DYI setup), were you out of alignment? I had an alignment done at a great reputable shop. They didnt have the tool on hand and i didnt have time to wait. They are fully aware of rear caster on the vette and viper. Rear tire wear looks good. Not sure if its worth going back.
So when you adjust camber you will likely change caster. Therefore it ought to be checked during the process.
Its probably not worth returning to the shop, as long as the car drives properly.
Caster is not a tire wear angle.
Mine was positive on one side and negative on the other which, while still in GM's wiiiiiide spec, could've cause some snap oversteer in a fast corner so I'm glad I got it checked. I'm not sure if it was that way from the factory or if the first dealer I took it to inadvertently set it that way when adjusting the rear camber (which was out of spec from the factory) because they didn't actually have the rear caster measurement tool. I asked, they said they did thinking I didn't know what I was talking about.
I ended up finding an independent shop that a lot of local weekend scca guys use with their vipers, 911s, Vettes, BMWs, Miatas, etc... He actually machined one for himself years ago for all of his C7 customers and set mine exactly where I wanted it. Took him an hour and cost $150. The dealer wanted me to pay $350 for them to rent the tool from GM and try again with the rear caster alignment - I quickly said no thanks. I've since found another local dealer that sells fewer C7s with a decent tech who can actually align the rear caster but they are just too expensive.
If you are really good on the track it might matter, otherwise forget it and DRIVE on!
Until you see the video in the other thread of a guy going around a corner on the street casually and snap oversteering into a ditch.
I personally want to guarantee mine is good and would advise others too. I am a strong supporter of alignments being a major factor on how a car drives. However, in actuality, you shouldn't have to worry in 99% of driving. If the car doesn't feel unusually unstable in corners, you are likely okay.
