Clutch Issue
Old Jul 23, 2020 | 03:01 PM
gs2011's Avatar
gs2011
Cruising
Default Clutch Issue
My 2017 ZO6.. 11,000 mile
Having problems with clutch sticking to the floor..
Took it first time to the dealer.. they change the Clutch Position Sensor.. problem short lived..
Took it back to dealer.. this time say water is in reservoir and clutch system causing the clutch to stick..
Have anyone had this issue..
Dealer say the had this issue before ..but in a C6..
All responses welcome..
Thank.. Garry
Old Jul 23, 2020 | 11:12 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Did the dealer replace the clutch fluid? If not I would find a new dealer since they found water in the fluid and didn't change it.
Old Jul 24, 2020 | 08:15 AM
Scruff Vette's Avatar
Scruff Vette
My clutch fluid was a mess at 9 months 2,800 miles from new. Clutch was making a strange noise taking off in first gear so I took the cap off. The fluid looked like cooking grease like there was moisture in the system (pic below). I normally use the "Ranger Method" to change clutch fluid out twice a year, but since the car was new I didn't do it. I swapped the fluid out using the Ranger procedure the next day and the problem is gone. Clutch fluid looks normal again, but I'm going to keep a close eye on it. I read that in C7's the clutch fluid line runs close to the exhaust which is why GM calls for the use of DOT 4 and recommends changing the fluid out at 36K miles.
On my '08 Z51 the clutch stuck to the floor once and after changing the fluid out using the above method, I never had the problem again. Video is of a C6 but same procedure for the C7.
Old Jul 24, 2020 | 08:36 AM
weathermaker's Avatar
weathermaker
I used the Ranger method on my C6 at every oil change. Traded car after 14 years and 65,000 miles. Never had a clutch problem. It takes several clean ups to get the fluid clean , but once clean it stays clean if you continue replacing it.
Old Jul 24, 2020 | 09:38 AM
Prime Target's Avatar
Prime Target
From: Murrells Inlet, SC (formally New Windsor, NY)
I had the dealer replace my clutch fluid at 7k. It looked like chunky soup. I’l keep it maintained using “Ranger” method from here on out. It gets dirty fast.
To Clutch Issue
