Starter problem
Old Aug 21, 2020 | 02:06 PM
marlborobill's Avatar
marlborobill
Cruising
Default Starter problem
I recently purchased a new 2019 Stingray A8. Occasionally, when starting, it will crank for a second or two then hesitate for a split second and then start cranking again until the engine starts. Fortunately this is a rare occurrence but I am concerned that it may be a starter issue. I previously owned a C6 so I am familiar with push button ignition. Any info on this would be appreciated.
Old Aug 21, 2020 | 06:18 PM
Bill Dearborn's Avatar
Bill Dearborn
I would say it is more of a control issue Vs a starter issue. The problem is it will be hard to know whether it is something to worry about or not.
Bill
Old Aug 22, 2020 | 07:55 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
Do you know how long the car sat on the dealer lot before you purchased it? I can bet that the battery went dead at least once it if sat more than a couple of months without being driven. It could be compromised and may not last much longer. I have not heard of your issue before but most electronic glitches can be traced back to the battery or a bad ground.
To Starter problem
