2014 Both Window Switches not functioning???
Old Sep 3, 2020 | 08:20 PM
spc54's Avatar
spc54
Default 2014 Both Window Switches not functioning???
Both driver and passenger side windows won't move. Using either switch on driver or passenger...
Ideas???
Old Sep 3, 2020 | 09:01 PM
RonC7's Avatar
RonC7
There are 2 fuses in the rear fuse panel with "window" in the description. I would start there. Check your manual for location and correct fuse # as numbers can change from year to year.
Ron
Old Sep 3, 2020 | 09:49 PM
spc54's Avatar
spc54
The driver side switch was originally not illuminated. Later tonight switch once again is illuminated. But driver side passenger switch not working, yet driver side switch working. And now passenger working again on passenger side.
But the fuse or battery. 😅
Old Sep 3, 2020 | 11:34 PM
RonC7's Avatar
RonC7
How old is the car battery? Old / weak batteries are known to cause electrical gremlins such as module to module communications issues. Buttons that light / don't light / light are likely not fuse issues, but could be dirty / loose connections or other wiring problems.
GL
Ron
Old Sep 5, 2020 | 12:01 AM
spc54's Avatar
spc54
Definitely the ground. Was a little dirty!
Old Sep 5, 2020 | 11:43 AM
Saved for future reference. Thanks.
Old Sep 5, 2020 | 04:28 PM
johnny3's Avatar
johnny3
Which ground? Battery ground?
Old Sep 5, 2020 | 04:52 PM
spc54's Avatar
spc54
I think so? Or just unplugging the battery did the trick? But definitely needs a new battery this one is the original from 14!
To 2014 Both Window Switches not functioning???
