Remote not found
Old Sep 16, 2020 | 09:04 AM
70vetteinpieces's Avatar
70vetteinpieces
Default Remote not found
Car won't start dash shows remote not found. take remote out of my pocket. same thing. dash shows place remote in steering column did that and car started right up. already late for work so I just drove it anyway. 2019 - could the remote battery be bad already? or do I have another issue? Don't use the button to lower the top but did buy the car used. Wonder if somewhere down the line one of the buttons was pushed and held down for an extended period of time to drain the battery. Lastly what battery do i need and will I have to reprogram it after I change it. Have the spare remote somewhere in my house
Old Sep 16, 2020 | 09:31 AM
RonC7's Avatar
RonC7
Certainly sounds like the fob battery. Replace with a new, fresh 2032. Avoid the brand with the textured back since it doesn't make as good electrical contact.
Batteries typically last 3 yr or so, but that's the average.
Ron
Old Sep 16, 2020 | 12:12 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Replace the battery in your spare fob too - they tend to die at about the same time. Buy them from somewhere that sells a lot, so you know they're fresh. Avoid Amazon batteries even if brand name.
The programming is in the car, not the remote. so don't do it. Can't help and could make it worse.
Only other reasonable possibility is something in your pocket or in the car that is interfering with car/fob transmission.
Old Sep 16, 2020 | 03:35 PM
Ultimate ride's Avatar
Ultimate ride
Just replaced the batteries in both fobs. Car was doing all sorts of weird things. Sometimes they would work sometimes not. The only way I could unlock the doors was to first pop the trunk lid. Other times-nothing worked for a while then they would suddenly work fine later. Everything is now back to normal. .
Old Sep 16, 2020 | 06:45 PM
Grand Slam's Avatar
Grand Slam
^^ Exactly my recent experience. Changed the fob battery and everything is fine now.
Old Sep 16, 2020 | 06:55 PM
vette2284's Avatar
vette2284
Bought my car in December. Once I got same message. Placed fob in slot and car started right up. It’s never happened again.
Old Sep 17, 2020 | 10:39 AM
70vetteinpieces
Replaced the battery and all good. Finding the battery was an issue. Local grocery store sold out, Wal-Mart sold out, final stop Lowes but only available in a 6 pack. Did replace the battery in the spare as suggested.
Old Sep 17, 2020 | 12:45 PM
vette2284's Avatar
vette2284
You jinxed me. Today 9 months later went out to start car. No fob found. It was in my jean pocket. Placed in slot. Car started. Started next 3 times no problem
Old Sep 17, 2020 | 04:51 PM
wgood's Avatar
wgood
I replaced both fob batteries and the car battery after 4 years
To Remote not found
