A8 flush
Old Sep 17, 2020 | 12:03 PM
Bikeman's Avatar
Bikeman
Default A8 flush
I know there’s lots in the forum regarding this and I’ve more or less looked at what’s been said. Opinions are just that but some are more expert than others.My 18 A8 definitely has the old hydrophilic ATF. While I’ve not had any major shudder or hard engagement the car does seem to a perceptible loss of smoothness in engagement now that it sits more since its not my daily driver. Seems intuitive the the new Mobil ATF is desirable even if no major problems. I’ve read the flush service instructions. Not done correctly your definitely asking for problems. So do we fix something that’s not broken. Looks like GM does not require Dealer confirm major problem,just owner complaint to do flush.Obviously not a big deal but as for most of us it is a little bit of pain to schedule service, take car in, come back etc.
Popular Reply
Sep 17, 2020, 12:14 PM
joemessman's Avatar
joemessman
You can't predict the future. The A8 is fine until it isn't. For peace of mind I would have the new fluid installed. Most never develop the issue.
Old Sep 17, 2020 | 12:14 PM
joemessman's Avatar
joemessman
Old Sep 17, 2020 | 01:58 PM
Borntorun04/17's Avatar
Borntorun04/17
I agree with joemessman that you can't predict the future and the peace of mind thing. That is why I had the Triple Flush done on my 17 GS which had NO symptoms of shudder. First why not have the correct fluid in tranny. My thought was why not do fluid change and possibly prevent more complicated and expensive repair which might show up after all warranties have expired. Regarding dealer I called and talked to service manager about 18-NA-355 and procedure and felt comfortable with them doing work. I also use the Range Device on my GS and Sierra pick up.
Old Sep 17, 2020 | 02:39 PM
dfkruger's Avatar
dfkruger
Make sure the service writer knows the procedure , has the tools provided by GM , The flush uses 5 gallons of LV ATF HP blue label . The Tec has preformed this before and knows the torque setting on the under shields 24 bolts . 22 13mm bolts at 20 fps and 2 18mm bolts at 74 fp . Stress the clean up . The drips on my garage floor spoiled the whole thing for me . Get it done .
Old Sep 17, 2020 | 02:46 PM
yellow2007's Avatar
yellow2007
As someone who has had 2 triple flushes done I would recommend it as a preventative measure.
Old Sep 17, 2020 | 03:17 PM
evoroadster's Avatar
evoroadster
I just had it done yesterday. Quick and easy. Go for it, especially if it won't cost you anything but a little time.
Old Sep 17, 2020 | 04:22 PM
Bikeman's Avatar
Bikeman
Thanks guys. Looks like we are all on the same page. Now all I have to do is find some time to overcome the aggravation of trundling back in to the dealer.
Old Sep 17, 2020 | 04:27 PM
bankers1's Avatar
bankers1
My '17 GS has had 2 with the "New" fluid. I still have a vibration/warbel sound between 1,100-1,300 RPM with slight acceleration in any gear all the time. It's been in the shop for it's 3 trip this year for the past 5 days.
Old Sep 17, 2020 | 05:43 PM
Bikeman's Avatar
Bikeman
What kind of mileage and driving?
Old Sep 17, 2020 | 05:52 PM
Dougyfd's Avatar
Dougyfd
A vibration / warble sound is not a symptom of the transmission shudder. Something else is causing that.
Old Sep 17, 2020 | 06:03 PM
MMD's Avatar
MMD
You're on the wrong thread. Your issue relates to the carrier /differential. I had to have my carrier replaced on my 19GS to fix the problem you are experiencing. Use the search here. Search for warble and differential. Many threads posted that talk about this.
Old Sep 17, 2020 | 06:07 PM
joemessman's Avatar
joemessman
This is most likely what you need based on what you have stated:
Old Sep 18, 2020 | 08:49 AM
bjones7131's Avatar
bjones7131
I had my 17 GS flushed as a precaution and seems to change smoother and also use Range device.
Old Sep 18, 2020 | 01:58 PM
kennyjames21's Avatar
kennyjames21
Is this covered under the 3yr or the 5yr powertrain? (I'd assume powertrain?)
Old Sep 18, 2020 | 02:22 PM
joemessman's Avatar
joemessman
5 year 60,000 miles. I actually just had the torque tube replaced on mine.
Old Sep 18, 2020 | 08:23 PM
ricmalaz's Avatar
ricmalaz
It's worth doing. My supercharged 650 rwhp '16 had the shudder really bad. I did the triple flush and have had no more shudders since. I did the flush 1 1/2 years ago and no issues (fingers crossed).
To A8 flush
