Fluids
Old Sep 24, 2020 | 05:27 PM
Ttrein76's Avatar
Ttrein76
Default Fluids
I am sure its in here somewhere, so my apologies. I spent some time searching here and my manual but did not find everything I needed. So here we ago
I am planning on doing an Oil/Filter, M7 Trans and Clutch fluid, Rear Diff Fluid change. This is a new to me 2017 Grand Sport M7.
Here is what I have so far with quantities:
1. Engine Oil - 9.8 Quarts Mobil 1 0W-40, PF64 Filter
2. Rear Diff -- 3 Quarts ACDelco Dexron LS 75W-90 gear
3. M7 Transmission Fluid -- Manual Transmission Fluid (GM Part No. 88861800) (Quantity UNKNOWN)
4. Clutch Fluid -- GM Part No. 19299570, Super DOT 4 brake fluid (Quantity UNKNOWN)
So, I am asking if anyone has the underlined quantities above, as well as any other suggestions... it is my first time doing this full service on this vehicle. I have a good friend with a lift we are going to use. Youtube video links welcome, he his very mechanically inclined however he hasn't worked on a C7 before. With that in mind, any other service recommendations while I have this opportunity? The car has approx 21,000 miles on it (19,000 when I got it and service history unknown).
Thanks! and again my apologies if I didn't find the thread that already had all of this.
Todd
Old Sep 24, 2020 | 05:53 PM
don7790's Avatar
don7790
4.3 qts for manual trans
Old Sep 24, 2020 | 05:54 PM
2019GSTX's Avatar
2019GSTX
Lurker
St. Jude Donor '19-'20
https://www.corvetteforum.com/forums...d-service.html
Check the stickies...great list of DIY's, service recommendations and procedures!
Have fun!
Old Sep 24, 2020 | 06:00 PM
MMD's Avatar
MMD
You might want to replace your brake fluid while you're at it.
Old Sep 24, 2020 | 06:15 PM
Skid Row Joe's Avatar
Skid Row Joe
Stop by any Chevrolet dealer and get a copy of your GMVIS report. It's going to have the records of when it was serviced at Chevrolet dealers, and what the procedures were, if any.
Old Sep 24, 2020 | 06:21 PM
LT4CMG's Avatar
LT4CMG
My 16 took about 3.2 qts of diff fluid and the trans, as mentioned above. Just about 4.5. I never did the clutch, so can't help. Maybe buy 4qts of diff, return one if you don't use it.
Old Sep 25, 2020 | 01:04 PM
JMII's Avatar
JMII
This thread will answer most of your questions regarding the tranny and diff fluids:
As for the clutch - most just use the Ranger method to exchange the fluid, 250ml was enough for me.
Old Sep 25, 2020 | 03:05 PM
Kracka's Avatar
Kracka
*EDIT*
JMII beat me to it!
Here's a write-up I did on the M7 and differential fluid change: https://www.corvetteforum.com/forums...d-service.html
Old Sep 25, 2020 | 04:29 PM
Kevin A Jones's Avatar
Kevin A Jones
I wouldn't recommend putting 9.8 quarts of oil in it or you may be burping up some into your intake.
9.5 qts at the very most, 9 is even better, then check.
Also:
There's a newer version of the PF64 filter. The old version, GM part number 12640445 has been superseded to 12696048, which is a little shorter and I believe the # of inlet holes changed as well.
Old Sep 25, 2020 | 04:41 PM
Skid Row Joe
"Ranger method" of routine DIY R&R of your clutch fluid reservoir is where it's at! Be certain to buy the DOT 4, fluid!👍
Old Sep 28, 2020 | 10:45 PM
MrClean21's Avatar
MrClean21
Todd
your C7 came with DOT 3 brake fluid from the factory. Don't know if you can mix them. Won't matter if you are doing a complete fluid replacement. See page 316 of the owner manual.
Old Sep 29, 2020 | 09:25 AM
JMII's Avatar
JMII
Clutch fluid is DOT4. Pentosin DOT4 LV is recommended.
Brake fluid is DOT3 but you can switch to DOT4 - and yes the two can be mixed. At some point the factory fill changed to DOT4 but the earlier cars had DOT3.
To Fluids
