Battery Protection Package
Old Oct 8, 2020 | 08:57 PM
Drkhrse's Avatar
Drkhrse
Default Battery Protection Package
I am sure there is a thread for this but I could not find it. When using the battery tender can you shut the rear hatch or do you have to leave it open? Thanks in advance for the information.
Old Oct 8, 2020 | 09:05 PM
MMD's Avatar
MMD
You can do either. The cord is not that thick so you could close the hatch if you wanted too. I'll leave mine partially open a crack. The rear hatch lights automatically turn off after a few minutes.
Old Oct 8, 2020 | 09:12 PM
Drkhrse's Avatar
Drkhrse
Thanks for the information.
Old Oct 8, 2020 | 09:52 PM
Toddhl's Avatar
Toddhl
As MMD said, you can do either. I close mine all the way. No damage to the cord or the weather stripping.
Old Oct 8, 2020 | 10:06 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
After participating in numerous such threads, I don’t even leave my C7Z connected to my battery tender anymore. I don’t drive it enough, but it averages out to 3 out of 4 weekends per month. It fires up every time.
Old Oct 8, 2020 | 11:00 PM
Kevin A Jones's Avatar
Kevin A Jones
As previously mentioned either way works. Your truck light goes off after about 10 minutes so no need to worry about it draining on the battery.
Old Oct 8, 2020 | 11:21 PM
I leave my hatch popped and just resting on the weatherstripping. But as said, you can also close it if you want.
Old Oct 9, 2020 | 02:28 AM
BillyC7's Avatar
BillyC7
I always was leaving the hatch unlatched until this year found several moths in the car. Started thinking about the spiders I have noticed in the garage, so now I close on the cord.
Old Oct 9, 2020 | 02:55 AM
BillyC7's Avatar
BillyC7
WOW! Just finished writing my reply and went out to the garage to get something and what did I see? First ever scorpion in the garage. Ain't Arizona wonderful. Closed hatch from now on.
Old Oct 9, 2020 | 09:37 AM
MMD's Avatar
MMD
Here is an innovative external battery connection to a C7 a little more elaborate for those concerned about critter ingressing your vehicle while charging your car battery.
https://www.ls2.com/forums/showthrea...hlight=battery
Old Oct 9, 2020 | 09:55 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
One advantage of leaving the hatch slightly open for the cord-
If you start the engine with the cord still in there, you get a bunch of lights and bells telling you that the hatch is open. Makes it (almost) impossible to pull out with the tender still connected.
No, I haven't done that yet. But other people, smarter than me, have made the mistake.
Old Oct 9, 2020 | 09:57 AM
dvilin's Avatar
dvilin
I just close the hatch completely as others stated cord is pretty thin no concern for damage.
Old Oct 9, 2020 | 12:35 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
that’s a good vote for “leave it open”. With my C6, I routed the Batt Tender cord out through the front grill. After backing out once and forgetting to uNplug it, I started putting a red rag on the windshield whenever it was plugged in.
Old Oct 9, 2020 | 01:45 PM
H Watkins's Avatar
H Watkins
St. Jude Donor '15-'16, '21,'24
I know I'm not as smart as Gearhead, but I now leave my hatch ajar as I made the mistake. I also printed out this sign and place it on the windshield facing the driver.
My thanks to another Forum member for uploading this originally.
Old Oct 10, 2020 | 08:59 AM
rckt's Avatar
rckt
Same reason here to close. Nothing worse getting in and feeling a web around you. Never again. Closed tight.
Old Oct 10, 2020 | 09:41 AM
Elk's Avatar
Elk
If critters want to get into your car they can easily do so, hatch closed or not.
It is not as if they examine cars, looking for an open hatch and declare "Let's go! This is the one!"
Old Oct 10, 2020 | 10:01 AM
Kevin A Jones
I agree, the average mouse can fit through a hole smaller than a dime. The way to stop rodents from getting into your car is to get rid of the rodents.
To Battery Protection Package
Old Oct 10, 2020 | 10:40 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
I leave the hatch open, which also as a bonus leaves the doors unlocked.
Old Oct 13, 2020 | 02:41 PM
wrecker3's Avatar
wrecker3
I use a Deltran Battery Tender and close the hatch. I do not want mice in my car !!! Just warm up the wire with a hair dryer an close the hatch. My C7 is 5 years old and no damage to the paint or body !!!
Old Oct 13, 2020 | 06:03 PM
Gearhead Jim
St. Jude Donor '13
Unfortunately.
We had a Toyota that was a lot tighter than any Corvette, parked in our garage. If we left a bag of dry dog food inside, the chipmunks would get in and chow down.
Chipmunks are smaller than rats but a lot bigger than mice.
Finally we eliminated the problem by eliminating the chipmunks.
