infotainment screen error HELP!
Old Oct 10, 2020 | 05:30 PM
redrocketship's Avatar
redrocketship
St. Jude Donor '09
Default infotainment screen error HELP!
After installing a Soler TB and cold air intake, I unhooked the battery for a few days so the ECU would reset fuel trims. After hooking the battery back up and going for a 50+mile drive, I'm consistently getting Network Unavailable message on the screen. I can hit the close app button and within a couple of minutes, it comes back. The vehicle is connected to WIFI hotspot, just like it was before the battery was unhooked. Anyone seen this before?
Old Oct 10, 2020 | 08:27 PM
c54u's Avatar
c54u
According to the picture you posted, it looks as if your car is not connected to a wifi network. On my 2017 model, an icon appears to the right of the 4G LTE showing it is connected to WiFi.
Go into Wi-Fi Networks and Forget/Delete/Remove the network you think you are connected to and redo the WiFi connection again.
This link shows the missing icon on your screen. Red arrow points to your missing icon.
https://www.corvetteforum.com/forums...post1597949301
Old Oct 11, 2020 | 11:01 AM
Stackenali's Avatar
Stackenali
Need to "Forget" your old network and reconnect. Should work after that.
Old Oct 11, 2020 | 02:16 PM
redrocketship
St. Jude Donor '09
I'll try that, thanks for the tip!
Old Oct 14, 2020 | 01:54 PM
redrocketship
St. Jude Donor '09
Tried this and still getting the error. Anyone have any other suggestions??
Old Nov 24, 2021 | 11:57 PM
eswirl's Avatar
eswirl
1st Gear
Did you ever get anything figured out? I’ve got this same exact issue with my 2018 Z71 and it’s very frustrating. Same exact cause, disconnected the battery.
To infotainment screen error HELP!
