C7 dash lights
Old Oct 15, 2020 | 04:22 PM
tomgoe's Avatar
tomgoe
Cruising
Default C7 dash lights
2014 Stingray . The dash light will intermittently go off . Sometimes could be after an hour , or 10 minutes . Will at times come back on in a few seconds , may be 20 minutes before they come back on . They don't dim - just totally off . The dash dimmer is set to the highest position . Anyone else having this problem ? Don't know where to begin to even troubleshoot
Old Oct 15, 2020 | 05:10 PM
c54u's Avatar
c54u
The problem could be the auto light sensor located on top of the dash. Part #16
https://www.gmpartsdirect.com/v-2014...r-and-switches
Old May 12, 2021 | 02:53 PM
rickster1823's Avatar
rickster1823
did you solve this issue?
Old May 12, 2021 | 05:33 PM
Grand Slam's Avatar
Grand Slam
My car dims the dash significantly at dusk and dawn. Doesn't seem to correctly interpret the lighting. Is yours happening at these times?
Old May 12, 2021 | 05:53 PM
tomgoe's Avatar
tomgoe
Cruising
No - it happens in the middle of the day and way past dusk . I think it is a loose connection , but nearly impossible to get under there to check
Old May 12, 2021 | 06:51 PM
Hope you can find the source of the problem. I’m sure a number of people will be interested in what you find out.
Old May 12, 2021 | 07:19 PM
1000RR's Avatar
1000RR
Please share the solution when you get it. I'm just impressed it's been 7 months and it's still not fixed... I wouldn't be able to stand that not working properly for more than a couple weeks. Maybe the cars been stored for the winter though?!
Old May 13, 2021 | 12:09 PM
tomgoe's Avatar
tomgoe
Cruising
Yes , car has been driven very little since November , and haven't received any useful info as how to resolve the the problem
Old May 13, 2021 | 09:23 PM
rickster1823
Guys, check out my thread. It is a similar issue that my local dealership will end up fixing. There is a possible solution in one of the responses by a fellow member of the forum.
Old May 13, 2021 | 09:24 PM
rickster1823
link below.
https://www.corvetteforum.com/forums...post1603449397
To C7 dash lights
