a6?
Old Oct 18, 2020 | 07:50 AM
firstvette99's Avatar
firstvette99
Default a6?
is the a6 something to stay away from on a 14 c7?
Old Oct 18, 2020 | 08:13 AM
DALE#3's Avatar
DALE#3
It actually was the better tranny.
Old Oct 18, 2020 | 08:54 AM
Kevin A Jones's Avatar
Kevin A Jones
No, the A6 is a very durable/reliable automatic transmission.
Old Oct 18, 2020 | 08:57 AM
firstvette99
What about performance vrs m7
Old Oct 18, 2020 | 09:19 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Welp, there is no way in hell you'll be able to hold the RPMs and out-shift the A6. It depends on what you want. You just went from how good is the A6 and that is "***** to the wall great" to a new topic of auto vs manual.
Elmer
Old Oct 18, 2020 | 09:26 AM
Kevin A Jones
Here we go again, I expect this thread to be pounced on by the resident M7 fanatics in short order.
Old Oct 18, 2020 | 10:07 AM
firstvette99
It is not a a6 vts nm7
it's a a6 vts a8..
Old Oct 18, 2020 | 10:23 AM
fyreline's Avatar
fyreline
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
The A6 is a much more reliable and bulletproof transmission than the A8, and it can shift faster than you (or anyone) can shift an M7. Use the paddle shifters if you absolutely HAVE to play boy racer.
Old Oct 18, 2020 | 10:26 AM
eboggs_jkvl
Moderator emeritus
it's a a6 vts a8..
Well, your OP says,
Since the A6 was ONLY in the 14, and you point to the 14, there is no A8 to compare it to. The A8, after they figured out the issues, is a good transmission. I have the 14 and the A6 is rock solid and has performed perfectly.
So are we talking about the 14 and how good the A6 functions?
The M7 vs A8?
The A6 vs A8?
I don't have a clue what you are asking at this point. I think I'll simply let the other folks in here figure out the topic.
Elmer
Old Oct 18, 2020 | 10:38 AM
firstvette99
Sorry for the confusion I will just have to go drive a 14 a6 and see if it performans as well as the 15 and up with the a8
thanks
Old Oct 18, 2020 | 10:43 AM
The A6 is a very good tranny that has proven to be very reliable over the years.
The A8 has had its share of problems but in Feb 2019 GM supposedly arrived at a fix. Time will tell how well the fix works but so far it looks promising.
Not sure just what else you want to know about either transmission.
Old Oct 18, 2020 | 11:45 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Automatics on the newer Corvettes are undisputedly faster than manual, but do you want to just drive or do you want the visceral feel of banging thru the gears.. some just feel more "sporty" shifting manually.. up to you really.. test drive both types and see what you like better
Old Oct 18, 2020 | 11:48 AM
eboggs_jkvl
Moderator emeritus
thanks
OK, fair enough. One more point to consider in your comparison and that would be Z51 or not. The Z51 package gives a different gearing ration in the transmission. It is supposed to be quicker.
Elmer
To a6?
