C7 Oil Change Step by Step Guide
Old Oct 27, 2020 | 08:20 AM
pavell's Avatar
pavell
Default C7 Oil Change Step by Step Guide
is there any step by step picture guide for a c7 non-dry sump oil change?
thanks,
Old Oct 27, 2020 | 08:36 AM
Zjoe6's Avatar
Zjoe6
See below. I misread the request as dry sump instead of non-dry sump.
Old Oct 27, 2020 | 08:44 AM
pavell's Avatar
pavell
Originally Posted by Zjoe6
This is the one I used. Our own forum member Ozzstar. Pay special attention at 3:26 where he says how to warm the car up for the oil change and how to properly check the oil level.
https://www.youtube.com/watch?v=Q8A4...zzstar%27sCars
I'm looking for regular c7 NON-dry sump. doesn't the grand sport have a dry sump system?
Old Oct 27, 2020 | 10:49 AM
PHXATC's Avatar
PHXATC
https://www.corvetteforum.com/forums...-stingray.html
Putz around in there.
Old Oct 27, 2020 | 10:53 AM
MMD's Avatar
MMD
I found that warming up the car is a unnecessary. It wastes gas and puts more wear and tear on cold starting the engine. I will pull both drain plugs and filter on a cold engine and just leave the vehicle draining for about 4 hours, Doing it this way will get every last drop of oil in the engine. I have checked the oil level after replacing the oil and have found it will take every drop of the 9.8 qts that GM recommends for the LT1. Two tips I highly recommend is too take off the oil fill cap before you start the oil removal process. Leave the cap off for the entire process. This will make it easier for the oil to flow during the draining process. Also, preload the new oil filter with oil before you reinstall the new oil filter. This will aid in getting the oil flowing quicker through the engine on the cold start.
Old Oct 27, 2020 | 10:57 AM
MMD's Avatar
MMD
Yep. Draining oil is not rocket science. Sting ray and GS use same oil, it just uses slightly less of it (7 qts versus 9.8). The GS has one additional drain plug than does the Sting ray.
Old Oct 27, 2020 | 11:48 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Get it up while warm if you can do it, if not just drain it longer. You only have 1 plug to remove. Swap out the filter with the correct one. Put the plug back in. Fill it with the correct amount of oil and you're done.
Elmer
Old Oct 27, 2020 | 12:47 PM
Zjoe6's Avatar
Zjoe6
Must have misread you post as dry sump. I fixed it.
To C7 Oil Change Step by Step Guide
