Help! Brake Squeak from Hell!
The solution for me was to do a weekend of autocross, or a hard blast on a twisty road with some hard braking. Repeat as necessary, maybe every 3k-5k miles.
One time on the 2017 I let it go too long and had to do the complete brake bedding procedure.
Bill Dearborn once suggested simply using the brakes harder than normal, but not brutally, in your normal driving. At every stop sign, delay your braking until you're half the distance from the sign where you would normally start braking. If that isn't enough, abuse them enough to get rid of the noise and start again, braking even a little later. But don't be dumb, allow yourself enough distance to be safe on slicker pavement.
the brembo squeak was so annoying. Worst when stopping and rolling to the stoplights.
Instantly dried up panties
was so embarrassing with a sports car with squeals and squeaks
i took out the pads and lubed all the backs. Still squeaked
fianlly went to rock auto and bought what everyone recommends - power stop z23
best decision wver
