Lumbar Support
Old Nov 10, 2020 | 09:57 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
Default Lumbar Support
I just bought a 2015 3LT coupe with 24,000 miles. The power lumbar support on the drivers side seems to have an issue. I can hear a click when I try to operate it but the motor doesn’t run like the passenger side does. I did a search and found some issues with leaking but nothing about it being inoperative. Anyone else have this problem and if so how do you fix it?
Old Nov 11, 2020 | 11:27 AM
Jason86's Avatar
Jason86
Mine did this too. I took the drivers seat out of the car. Pulled the back off of the seat and found the motor. The motor was stuck--not turning. I took the motor apart, lubricated with some 3 and 1 oil. Been working ever since!!! You will have to unbolt the seat belt to remove the seat. Disconnect the battery just in case as the seat has an airbag system.
Old Nov 11, 2020 | 01:33 PM
dan1495's Avatar
dan1495
Thank you very much, that makes a lot of sense.
Old Nov 11, 2020 | 01:54 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Nice!
To Lumbar Support
