3LT Dash fix
Old Nov 14, 2020 | 09:55 PM
Jmhornz71's Avatar
Jmhornz71
Default 3LT Dash fix
I havent seen this anywhere so I thought I would mention it. There is a C7 Corvette facebook page. Several folks there mentioned using a steamer on their 3LT dash. The heat and steam softens the glue and can also shrink the leather and for the most they say their dash looks good again. No mention so far how its holding up though. I may try this and if it fixes 90% of the lifted leather it will be worth it
Old Nov 14, 2020 | 10:13 PM
I guess it's worth a try - especially if you are out of warranty and the replacement would be on your dime. Just hope it would not damage the dash any more than it already is.
Old Nov 14, 2020 | 10:23 PM
Kevin A Jones's Avatar
Kevin A Jones
Hope it works out for you. Why don't you take a before and after photo to share?
SmittyC7's Avatar
SmittyC7
Don't want to hijack this thread, but is it generally thought that cars sitting out in the hot sun are more likely to have this problem? I just bought a 2015 3LT and the dash looks great - but it was more or less a garage queen. I know there has been a lot of discussion about this and I have read some of it. Didn't seem to be a consensus on the cause.
Baking and shrinking in the hot sun and then steaming to restore the shape seems to make sense.
Old Nov 14, 2020 | 10:34 PM
Jmhornz71's Avatar
Jmhornz71
I will when I get to do it or take to a place to have it done. The pics I saw on facebook the dashes looked good.
Old Nov 15, 2020 | 12:42 AM
stevettec7's Avatar
stevettec7
Though mine is by no means a “Garage Queen” because I drive her, but mine rarely sits for long periods in the sun and I have the dash problem. So, heat surely is related in a lot of cases, but I’m sure there are some where it isn’t.
If anyone tries the steam method, please report your result. I’d hate to see it actually do more harm than good.
Old Nov 15, 2020 | 07:21 AM
Dundee's Avatar
Dundee
To try this super wet a towel and place a hot iron on it momentarily while the towel is over the bubble.
Doesn't take but a few seconds for the iron and towel to produce a lot of steam.
This method can also be used to remove dings from wood floors and furniture..
I rebuild old Chris Craft wood boats and use this method to remove small dings in the hull.
Old Nov 15, 2020 | 09:05 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Great tip ! I've used the "wet towel" method outside in the hot summer sun on new leather seat skins. It takes time but works great.. They turned out really nice.
Old Nov 15, 2020 | 10:45 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Post up a review of your method and if it works or not...
Old Nov 15, 2020 | 11:11 AM
yellow2007's Avatar
yellow2007
I used the following tools to try and repair mine. My separation was only at the edge of the defroster vent.The leather really can't be stretched but it can be manipulated. I bought several detailing syringes, fabric cement and forceps. Grabbing the edge of the leather, lifting and pulling gently I would inject the glue directly onto the dash and then lower the leather onto it. The cement is quick dry so I only had to hold it in place for a bit. It is perfect? No. Will it hopefully mitigate further de lamination? I certainly hope so. Here are the tools used.
Old Nov 19, 2020 | 07:14 PM
Jmhornz71's Avatar
Jmhornz71
Today I went to auto upholstery shop recommended by my service writer. I trust him. They looked at the dash and said the only way to repair it is to tear it apart. He said steam would probably make the leather shrink which is what has caused the problem already. But the leather GM uses isn't really a hide but some concoction they made. So I will probably end up buying a steamer and trying it myself. It already looks like crap I cant hurt it much more. I'll get pics when I do it.
Old Nov 19, 2020 | 07:28 PM
Always Red Dave's Avatar
Always Red Dave
Good luck and look forward to your results!
Old Nov 19, 2020 | 07:48 PM
Elk's Avatar
Elk
Good luck!
I wish you success.
Old Nov 22, 2020 | 08:40 AM
CPO Rob's Avatar
CPO Rob
Veteran: Coast Guard
I saw that thread also. I will say that prior to getting the Car, I purchased this and have used it all the time
To 3LT Dash fix
