Range Module Periodic Removal
The electronics certainly do not care. I cannot think of anything mechanical which needs to be exercised. Thus, I would not bother.
We know one needs to pull the unit and drive a bit before emissions testing, but this is a different issue.
Others may have more insightful responses.
A range has been plugged in my 2015 A8 since the day I bought it and now at 47,000 miles , I have AFM disabled in the tune
So my opinion, there is no need to " EXERCISE" AFM unless you need to unplug the range to pass emissions
Dave
Nobody will say the car has a tune as the range does nothing to the orginal tune or CVN files which is what GM looks at to determine is the ECM tune files were modified . All the range does is fool the AFM module into thinking that the requirement for AFM are not met using the CANBUS .( communications bus) .. . Heck my dealer even knew what the range was because he has seen so many if them as the range is not just for the Corvette....
Dave
Dave
Dave
Dave
Still not sold that AMF causes the transmission issues as reported. If anyone has any official engineering information that supports this info, I would like to read it. Don't toss rocks.. Just want too see proof that the AMF system causes the trans issue. I'll buy a Range device if documented proof can be sent my way..
Maybe I will look at it as if I need to go do one of those inspections every year. Probably no correct answer on this one.
IMO.. A Range device is perfect if you don't want to run in 4 cylinder mode. But probably a waste of money if you think it will stop the transmission shutter issue.
AFM did not work in the 80's and it still does not work in 2020 yet it keeps getting jammed down our throat to satisfy some CORP fuel economy standard that GM has to meet
Anybody remeber the 4 6 8 engine that was installed in the 80's Eldorado lol
There are two problems here with 4 cylinder mode
With AFM no proof needed just ask anybody that has suffered an AFM lifter failure along with sometimes wiping out the lifter bore or cam . AfM lifters and the system that operates them is full of issues
The second problem is not really an AFM issue but a result of the car going into 4 cylinder, the shudder issue with the A8 , GM is blaming it on hydroscopic fluid ... which might play a part in it but it really is caused by the TCM programing and how the TCM locks up the converter during cruise situations, the TCM does not actually lock up the converter as that would pass the unbalance vibrations of running in 4 cylinder mode to be passed thru to the driveline , The TCM pulses lockup never achieving a full lockup. The real cure is to modify the TCM programing which they did and is part of the triple flush procedure along with a garage relearn procedure ( Google it )
Want proof ... ask anybody who replaced the stock converter with an after market and tuned the transmission .... I still have my stock converter, and that nasty old hydroscopic fluid but..... I have the latest TCM firmware and my trans has been tuned .... 47,000 miles of no shudder for me
Hence the reason why folks use the Range , stop AFM , stop the TCM from pulsing the converter
There are some cases where the converter is to damaged and the fluid or the programing is not going to help
Then there are other issues that setup a harmonic imbalance that mimics the trans shudder Everyone is quick to blame the trans and do the flush when a simple pico test would point to the real cause of the shudder ....which is usually the heavy runflat tire balance
Don't by a range no skin off my back but if you experence a collapsed AFM lifter because you want engineering data lol lol
Heck just Google AFM lifter failure
Dave
I too have heard stories about members failing smog inspection due to the car stating not ready for testing if the Range device was just removed. Might be good to drive the car a bit after removal just to be sure.
I no longer use it in my Stingray. I simply drive in manual mode all the time.
I normally drive with the device plugged in all the time. I was initially sharing one device between my Avalanche and Stingray. One day while driving the Avalanche without the Range, I noticed a Check Engine light. I immediately pulled the code and found P0420, Catalyst System Efficiency Below Threshold on Bank 1. I had just installed 4 brand new O2 sensors and 2 brand new catalytic converters. We (the dealer and I) went through the series of checks...making sure I had good sensors all the way around and I eventually forgot about it because they couldn't find anything wrong with the sensors or the truck. I needed to put some miles on my Stingray for the extended warranty period, so I parked the truck for about 2 weeks.
While heading to Lowe's one day, I hopped in the truck and then thought to grab the Range device. Popped it in and went about my day. Forgot all about the CEL because it was gone by the time I looked at the display.
To go along with my newly assigned science project, I disconnected the device that afternoon and drove about 15 miles away. The CEL returned....same code. Connected the Range and the code disappeared instantly. This went on for the next 600 miles.
I know there's a genius out there who can tell me what the exact cause of this was, but until I run into them, I am not using the Range in my Stingray again. Manual mode works fine for me...
I've actually driven in Manual mode so much that I don't believe I would drive the Stingray any other way.
#MrFlappyPaddles!
Now if you drive it long enough for the ECM to do a second check. U will pop a code as its only on startup that it clears any code
Dave
Dave
