GPS Screen
Old Dec 18, 2020 | 07:59 PM
Robyellow68's Avatar
Robyellow68
1st Gear
Default GPS Screen
Is there something the will clean tne GPS screen? Mine has finger prints on it that i can not get cleaned off.
Old Dec 18, 2020 | 09:59 PM
laserdude2215's Avatar
laserdude2215
My owner's manual says to gently clean by rubbing with a microfiber cloth.
Old Dec 18, 2020 | 10:30 PM
FX VETTE's Avatar
FX VETTE
What have you tried to clean it off with? Nearly everything in my detail arsenal works for me, including a damp microfiber towel. Unless you work at KFC or something, I don't know why you can't get the prints wiped off rather easily.
Old Dec 18, 2020 | 10:34 PM
A clean microfiber towel works well to clean the screen on my infotainment system.
Old Dec 19, 2020 | 09:19 AM
yellow2007's Avatar
yellow2007
After cleaning try this
Old Dec 19, 2020 | 09:55 AM
49FIS's Avatar
49FIS
I installed the screen protector on mine, solved the finger print problem. Easy to clean. No worries about damaging the screen.
Old Dec 19, 2020 | 02:22 PM
yellow2007's Avatar
yellow2007
After I installed the protector on mine I use this now to touch the screen
Old Dec 19, 2020 | 02:39 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I keep a very small microfiber towel in the area behind the screen. When, necessary, I usa it to wipe the screen.
Old Dec 19, 2020 | 03:41 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Almost anything will remove fingerprints on the surface of our 2017 nav screen. But once the fingerprints are removed, there are still marks where my finger has pressed on many of the screen "buttons". The marks are only visible when the light hits at certain angles, but very visible then.
I've very carefully tried plastic cleaners, glass cleaners, detail spray, damp rags, even rubbing alcohol. None of those cleaners has damaged the screen, but none of them will remove the marks. I keep my fingernails short and don't use anything else to press the screen "buttons", but there is definitely some kind of minor damage there.
Old Dec 20, 2020 | 01:07 PM
joemessman's Avatar
joemessman
If you decide to go the screen protector route after cleaning it, this is a very good product and fits perfect.
Amazon Amazon
To GPS Screen
