Auxiliary Function
Old Dec 20, 2020 | 08:38 AM
max suntato's Avatar
max suntato
Default Auxiliary Function
I own a 2017 Lt1 Stingray. My question, is there any way to utilize an auxiliary function with the engine off? Like tire pressure, MPG, Etc.
Old Dec 20, 2020 | 09:40 AM
Elk's Avatar
Elk
Yes, hold down the start button without pressing the brake. After five seconds or so all the electronics will be powered without starting the engine. This is Service Mode. (It is in the manual.)
Note however this is a significant drain on the battery, Do not leave it in this mode for long.
Old Dec 20, 2020 | 09:47 AM
myfunweecar's Avatar
myfunweecar
I'm not sure tire pressure will be correct though. I thought the sensors went to sleep after motion was no longer detected. So the value in the computer is the last value before the tire sensor went to sleep.
Old Dec 20, 2020 | 10:12 AM
^ I do believe you are right.
Old Dec 20, 2020 | 11:04 AM
joemessman's Avatar
joemessman
I inflate mine while in service mode and the pressure is adjusted.
Old Dec 20, 2020 | 11:08 AM
max suntato
Problem solved! You guys are great! It's like having my own private mechanic. Anyone have a cure for baldness? Thanks, saved me a few hairs, Max.
Old Dec 20, 2020 | 11:15 AM
PJG65's Avatar
PJG65
Yea, a Corvette!
Old Dec 20, 2020 | 11:24 AM
dbdave's Avatar
dbdave
The drain can be lessened by turning off the headlights and the HVAC fan.
Old Dec 20, 2020 | 11:38 AM
Elk's Avatar
Elk
Yes, ask us before pulling your hair out.
To Auxiliary Function
