Dash wire help needed after replacing dash
Old Dec 28, 2020 | 06:37 PM
socal_tom's Avatar
socal_tom
Default Dash wire help needed after replacing dash
Hi Guys
I replaced my dash on my 2014 z51 convertible and here is the deal, I know where all the wires plug back in except this one with the red end. If you look at the pictures it's the the wire next to the starter switch on the right of the picture. Thanx in advance for any help guys. I plugged a few wires back in to start the car and of course starts no problem .
Old Dec 28, 2020 | 09:20 PM
Tom - will be interesting to see the responses you get on what that wire goes to.
Old Dec 28, 2020 | 09:26 PM
helomech's Avatar
helomech
I don't know for sure, but lots of times there are wires that don't go anywhere. I see it often, on my cars and in aircraft.
Old Dec 28, 2020 | 09:50 PM
socal_tom's Avatar
socal_tom
Thanx Jack I plugged back in some switches I took car and started the car of course it's still apart but I counted all the switches and the plugs to the dash and I wasn't missing anything. I can not figure where this wire came from . If I have to I will plug back in all the wires before put I mount everything solid to see what comes up . It has me stumped
Old Dec 28, 2020 | 11:12 PM
RonC7's Avatar
RonC7
Is there any marking on the connector? What trim level and trans do you have?
Connector might be for an option that you don't have...
Ron
Old Dec 29, 2020 | 10:06 AM
Bigredwing's Avatar
Bigredwing
Do you think it goes to the dash or steering column? Maybe somebody that has installed a throttle controller and run wires under the dash has pictures from underneath and can help. Too late now but this is why I have lately been taking pictures of things before and during disassembly. Tech all my life but I have a terrible memory.
Old Dec 29, 2020 | 10:27 AM
JMII's Avatar
JMII
Total guess - how about the slot where the FOB goes for reprogramming?
There has to be some electrical connection to make that slot functional...
Old Dec 29, 2020 | 10:37 AM
quaters's Avatar
quaters
I just replaced my dash last week (2016 2LT Z51). I had 6 connectors 3 on each side -- Right side was ignition, hazards and radio/hvac harness. Left side was HUD, Interior lights and mirrors.
Judging by my pictures that wire must go the steering column.
No Red Harness
Old Dec 29, 2020 | 10:41 AM
socal_tom's Avatar
socal_tom
Thanx for the input guys I'm sure it's not to the dash because all the plugs have been accounted for . My car is a 3LT so it's pretty loaded and I have been trying to trace it by the length of the wire . Once you have the dash off there is really not that much there and it's pretty easy to tell where things go
Old Dec 29, 2020 | 12:01 PM
Jeff V.'s Avatar
Jeff V.
Someone get this man a prize. I just looked it up in the service manual and you are absolutely correct.
Old Dec 29, 2020 | 12:28 PM
socal_tom's Avatar
socal_tom
I believe he is correct with the steering column it's the only place that makes any sense to me due to the length of the wire. When I go down to my shop this morning I am going to really look close . I was looking there last night with a mirror and will look again today while I have plenty of day light, Thanx guys for all the replies I know I can always count on the team
Old Dec 29, 2020 | 12:34 PM
Bigredwing's Avatar
Bigredwing
Thanks for the photos. I have a folder I keep all this kind of stuff I find on the forum. When needed it's gold!
Old Dec 29, 2020 | 02:27 PM
JMII's Avatar
JMII
Thanks for the confirmation. The location, length and missing column cover pointed me towards the FOB slot. Plus red is the default color for "switched 12v+" aka ignition. Years of installing car stereos have given me spidey-sense when it comes to wiring
Old Dec 29, 2020 | 09:41 PM
socal_tom's Avatar
socal_tom
I found it guys by searching the length of the wire . I looked all over that steering column with a flashlight and mirror during the sunlight today and nothing , so I went back to the steering column covers I had taken off and BAM!!!!!! there is was on the inside of the top cover problem solved . Thanx for everyone's input.
Tom
Old Dec 30, 2020 | 07:15 AM
449er's Avatar
449er
CF Community Team
Some good help here, thanks to JMII
To Dash wire help needed after replacing dash
