Thermostat / Ext. Warr.
A. For any of the following parts: carburetor, battery and battery cable/harness (unless listed as specific covered parts), standard transmission clutch assembly, friction clutch disc and pressure plate, distributor cap and rotor, glass, lenses, sealed beams, light bulbs, fuses, circuit breakers, cellular phones, game centers, AM/FM radio/cassette/CD players exceeding $3000 repair or replacement cost, speakers, audio/video equipment, any pixel damage on display screens, electronic transmitting/receiving devices, remote control consoles, radar detection
devices, brake rotors and drums, all exhaust components, and the following emission components: EGR purge valve/solenoids/sensors, vacuum canister, vapor return canister, vapor return lines/valves, air pump/lines/valves, catalytic converter/filtering/sensors, emission vapor sensors, gas cap/filler neck, weather strips, trim, moldings, bright metal chrome, upholstery and carpet, paint, outside ornamentation, bumpers, body sheet metal and panels, frame and structural body parts, vinyl and convertible tops, any convertible top assemblies, hardware or linkages, tires, wheels/rims. External nuts, bolts and fasteners are not covered except where required in conjunction with a covered repair.
B. For maintenance services and parts described in Your Vehicle’s owner’s manual as supplied by the manufacturer and other normal maintenance services and parts which include, but are not limited to: alignments, adjustments, wheel balancing, tune-ups, spark plugs, spark plug wires, glow plugs, hoses, drive belts, brake pads, brake linings/shoes, and wiper blades. Filters, lubricants, coolants, fluids and refrigerants will be covered only if replacement is required in connection with a Breakdown.
C. For any damage and/or Breakdown resulting from collision, road hazard, fire, theft, vandalism, riot, acts of terrorism, explosion, lightning, earthquake, freezing, rust or corrosion, windstorm, hail, water or flood, acts of God, salt, environmental damage, chemicals, contamination of fluids, fuels, coolants or lubricants.
D. For any Breakdown caused by misuse, abuse, negligence, lack of normal maintenance required by the manufacturer’s maintenance schedule for Your Vehicle, or improper servicing or repairs subsequent to purchase. For any Breakdown caused by sludge build-up resulting from Your failure to perform recommended maintenance services, or failure to maintain proper levels of lubricants and/or coolants, or Breakdowns caused by fuels containing more than 10% Ethanol (if the engine was not manufactured for this fuel mixture), or failure to protect Your Vehicle from further damage when a Breakdown has occurred or failure to have Your Vehicle towed to the service facility when continued operation may result in further damage. Continued operation includes Your failure to observe warning lights, gauges, or any other signs of overheating or component failure, such as fluid leakage, slipping, knocking, or smoking, and not protecting Your Vehicle by continuing to drive creating damage beyond the initial failure.
E. For any repair or replacement of any covered part if a Breakdown has not occurred. Any part that a repair facility or manufacturer recommends or requires that it be replaced or repaired, or is an update, and is not a Breakdown, is Your responsibility and expense.
F. If any alterations have been made to Your Vehicle or You are using or have used Your Vehicle in a manner not recommended by the manufacturer, including but not limited to, the failure of any custom or add-on part, all frame or suspension modifications, lift kits, any tire that is not recommended by the original manufacturer if it creates an odometer/speedometer variance of greater than 4%, trailer hitches. Also not covered are any emissions and/or exhaust systems modifications, engine modifications, transmission modifications, and/or drive axle modifications, which includes any performance modifications.
G. If, while owned by You, Your odometer has ceased to operate and odometer repairs have not been made immediately, or the odometer has been altered in any way subsequent to purchase of this Contract.
H. If Your Vehicle has ever been a total loss, salvaged, rebuilt or is a grey market vehicle.
I. For any liability for property damage, or for injury to or death of any person arising out of the operation, maintenance or use of Your Vehicle described in this Contract, whether or not related to the parts covered. For loss of use, time, profit, inconvenience, or any other consequential loss, including any Consequential Damage to a non-covered part that results from a Breakdown.
J. For any Breakdown where the manufacturer is responsible for the repair or if the Breakdown is covered by a repairer’s guarantee/warranty (regardless of manufacturer’s or repairer’s ability to pay for such repairs).
K. If Your Vehicle is used for towing (unless Your Vehicle is equipped with factory installed or factory authorized tow package), or is used as a Commercial unit (unless appropriate surcharge is marked on Registration Page and only as defined under "Definitions", "Commercial Use"), or is used for rental, taxi, limousine or shuttle, towing/wrecker service, dumping (dump beds), cherry pickers, lifting or hoisting, police or emergency service, principally off-road use, prearranged or organized racing or competitive driving.
L. For any Pre-existing condition or for any Breakdown occurring before Coverage takes effect or prior to the Contract Purchase Date, or if the information provided by You, or the repair facility cannot be verified as accurate or is found to be deceptively inaccurate.
M. For Breakdowns that occur and/or repairs made outside of the United States of America and Canada.
N. For Diagnostic and/or Teardown procedures that are not listed, or are in excess of the times listed in the current year’s national flat rate hourly guide in conjunction with a covered repair.
KEY WORD: Break Down and then the repair.
Elmer
