Mode switch does not change the cluster appearanced
Old Jan 18, 2021 | 01:53 PM
plumalan's Avatar
plumalan
Default Mode switch does not change the cluster appearanced
When I change the mode switch the display does not change. It stays on touring mode all the time regardless of my mode selection.
Even when I choose track the cluster does not change but the tune of the exhaust changes. I have a 2014 Z51 with slightly over 19,000 miles on it.
Old Jan 18, 2021 | 01:55 PM
saleen556's Avatar
saleen556
I believe there is a display setting for this. You can have it stay the same or change with driving modes.
Old Jan 18, 2021 | 02:08 PM
dvilin's Avatar
dvilin
You need to go into settings and click link display to driving mode.
Old Jan 18, 2021 | 02:46 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Use the buttons on the steering wheel and get into the settings. It is :locked" on one display. You can select another display to be "locked" on or turn it loose and the display will change with the big **** on the console.
Elmer
Old Jan 18, 2021 | 11:21 PM
This. Should get things to change as you want.
Old Jan 19, 2021 | 08:54 AM
JMII's Avatar
JMII
Make sure Link to Drive mode is on... my 2014 randomly forgets this setting for no apparent reason.
Old Jan 19, 2021 | 09:07 AM
eboggs_jkvl
Moderator emeritus
You make it run hard and squeal in the turns. It is getting even with you!
Elmer
Old Jan 19, 2021 | 09:28 AM
JMII's Avatar
JMII
I also drive it in the rain I'm surprised the doors still open to let me in given this level of abuse
To Mode switch does not change the cluster appearanced
