C7 Electric parking brake module
Old Feb 1, 2021 | 09:34 PM
Argentimage's Avatar
Argentimage
Default C7 Electric parking brake module
Is there anyone here that knows the ins & outs of the ebrake system?
Let me explain a bit - the pull up on the switch pulls the cable in setting the brake.
If it gets over extended - pulled in to the tip...how to release?
Part 2 is I do not hear the module reversing the action to push the cable out.
What is the test for this to see if it module or wiring?
I do not see any way possible to manually crank this back either...
appreciate the help
Old Feb 1, 2021 | 09:50 PM
laserdude2215's Avatar
laserdude2215
I don't know what this means.
But the car needs to be running with your foot on the brake pedal for the e-brake to release. You might be able to hear the motor run.
Old Feb 2, 2021 | 01:54 AM
Makitso's Avatar
Makitso
Saved this from a post on the forum, may help
Old Feb 14, 2021 | 06:01 PM
Argentimage
sure did thank you, thought I responded few weeks back on this looks to not have saved
my dilema is what kind of signal is the can message that says the foot brake and key on are active?
To C7 Electric parking brake module
