Removing one wheel question...
Old Feb 11, 2021 | 06:00 PM
bobbykart's Avatar
bobbykart
Default Removing one wheel question...
Gonna jack up one wheel to remove and ceramic coat caliper and wheel , have the puck and low hydraulic jack
should I use a jack stand to support, or my 7” x 20” wood block? And where to place it
Old Feb 11, 2021 | 06:53 PM
feastersss's Avatar
feastersss
C6 of Year Finalist (stock) 2019
This is a picture I saved from the forum, not my car
Old Feb 12, 2021 | 01:36 AM
I always use a jack stand as a safety measure.
Old Feb 12, 2021 | 07:39 PM
phalse's Avatar
phalse
...thats why he's called Jack-! hahahahahaha
i kid, i kid. but yeah, use stands, you can lift a car with a floor jack a thousand times and hold it up using the floor jack, a thousand times, and its totally fine.. until it isn't. and if some awful accident happens, what would one's conclusion be? shoulda had it properly supported.
Old Feb 12, 2021 | 09:23 PM
Kevin A Jones's Avatar
Kevin A Jones
Safety FIRST, they say!
Old Feb 13, 2021 | 05:27 AM
DALE#3's Avatar
DALE#3
Don't know why placement of stands are not on the cross member itself? My stands won't go where shown.
Old Feb 13, 2021 | 01:27 PM
Glock 23C's Avatar
Glock 23C
I use both large wood blocks and jack stands. Typically I use the jack stands when supporting the front and rear cross members. However on the sides I use my 12' x 12" wood blocks. I have used cement blocks also in lieu of the wood. Honestly I trust the wood blocks more because I feel they are more stable and can not slip out-more surface contact. As wisely stated above, make sure something is under there for your safety.
Old Feb 13, 2021 | 02:26 PM
Zjoe6's Avatar
Zjoe6
Moderator
See post #5 for correct jacking points. I like using the one posted in the pic right on the center of the cross beams. Nice wide pad.
Old Feb 14, 2021 | 09:44 AM
CraigStu's Avatar
CraigStu
I use 2 jacks. My normal aluminum jack at one puck point and then one of the tiny Harbor freight jacks at the other puck point. I started doing this when I noticed that I can jack up the entire side using either the front or rear puck point. The small HF jack is just $59 when they have one of their sales so it is almost less expensive than stands. BTW, this is only for when I am NOT going under the car.
To Removing one wheel question...
