2014 C7 alarm
Old Feb 16, 2021 | 10:32 AM
anderdea's Avatar
anderdea
Default 2014 C7 alarm
I have just purchased and programmed a second key fob for my 2014 Vert. I want to put the second fob in the trunk with the battery removed and just hide the mechanical key somewhere on the car.
My 2 question are:
1. With the doors locked will the mechanical key open the trunk so I can get my second fob?
2. If yes, will the alarm go off when the trunk is opened.
Old Feb 16, 2021 | 11:15 AM
Jeff V.'s Avatar
Jeff V.
Yes to both questions. I tried the same thing on my car.
Old Feb 16, 2021 | 12:56 PM
anderdea's Avatar
anderdea
So I guess that once the trunk is opened I need put the fob together ASAP in order to shut off the alarm. Opening the drivers door with the pull handle won’t shut it off.
Old Feb 16, 2021 | 02:23 PM
Jeff V.'s Avatar
Jeff V.
You might also try putting the fob into the pocket on the steering column and start the car that way. You don't need a working battery for that method. I don't know if this will disarm the alarm, but it's easy enough to try.
Old Feb 16, 2021 | 04:32 PM
laserdude2215's Avatar
laserdude2215
What's wrong with using this?
Magnetic Stash Box Magnetic Stash Box
Just wrap the fob in aluminum foil and you don't need to do anything with the batteries, worry about the alarm, etc.
Old Feb 16, 2021 | 05:40 PM
anderdea's Avatar
anderdea
Aluminum Foil? Where did you hear that would work? Don’t want to put the key on the car somewhere as there’s no really easy place to get to and there’s always the chance the key holder could get Jared loose. I’ve actually had the magnets stay on the car and the folder come off. Also there’s not many easy places on the vette (steel) that the holder can be attached to. If you correct about the aluminum foil, getting into the trunk is easy with the key and the fob if battery is still in it, I would be able to cancel the alarm pretty quick. The mechanical key being as small as it is would be easy to hide. Key ingredient here, aluminum foil.
Old Feb 16, 2021 | 05:54 PM
Jeff V.'s Avatar
Jeff V.
I wrapped mine in foil when I did my test. Didn't feel like taking the fob apart. You could also get one of those anti-RFD / faraday bags on amazon if you want something a little more durable.
Amazon Amazon
Old Feb 16, 2021 | 06:27 PM
anderdea's Avatar
anderdea
Thanks for the info and the link.
Old Feb 16, 2021 | 08:34 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
We've had a spare fob with battery, wrapped in aluminum foil hidden in the trunk of our Corvette (s) for the last 15 years. I test it every couple of years when I change the fob battery, the foil totally blocks the signal.
There are places outside the car where you can hide the key and it won't come off, we've had that for 15 years also and the Tech who works on the car still hasn't found it. It's not convenient, but secure and hidden, I can get the key without getting filthy.
As you can imagine, I could tell you but then I'd have to kill you...
Old Feb 17, 2021 | 08:41 AM
anderdea's Avatar
anderdea
Understand, thanks. I’ve already got a spot scoped out for the key. Thanks for everyone help.
Old Feb 17, 2021 | 09:54 AM
Maxpowers's Avatar
Maxpowers
Can you tell us and share your home address.
Old Feb 17, 2021 | 10:19 AM
MoosesC7GS's Avatar
MoosesC7GS
If you have your Vette set up to enable remote control via the MyChevrolet app (locking/unlocking) on your smartphone ( iPhone works great ) it wouldn't be necessary to hide a key as long as you have a working car battery. Opening this way does not set of the alarm. It might even give an owner a warm fuzzy if they had both remote control and hidden key.
To 2014 C7 alarm
