tire problem
Old Feb 18, 2021 | 12:38 PM
jarv33's Avatar
jarv33
Default tire problem
After driving my 2014 c7 stingray for a week I have found a problem.car has 21000 miles, I am being told from the dealer that this is normal with this size tire.{285/30zr20} 95y. Michelin pilot super sport,The problem is when I make a sharp with the stearing wheel in almost locked position the wheels bounce crazy and feels like something is wrong with stearing mech. They also told me even the new c8's do the same thing.I have purchased 3 cars from this dealer over last few years with no problem.Any ideas.?
Old Feb 18, 2021 | 12:55 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Normal with those tires. Nothing to worry about.
Old Feb 18, 2021 | 01:00 PM
Zjoe6's Avatar
Zjoe6
Old Feb 18, 2021 | 01:01 PM
TNSQUIRE's Avatar
TNSQUIRE
Completely normal
Old Feb 18, 2021 | 01:12 PM
seniorstorekeeper's Avatar
seniorstorekeeper
Agree with all above, common on C7 Corvette, thought my first car had hit a ditch or something, then found it is normal and they all have tire hop or chatter in tight turns at low speeds. I had to put a new set of tires on my car about 6 months ago, there were no Michelin run flat tires available in the 20" size so I had to get a set of Continental ExtremeContact non run flat tires. With the new non run flats, do not have any low speed tire hop whatsoever, have even went into parking lots and tried to get them to hop and they will not do it. Must be the compound the tires are made of or the fact of not having as stiff and sidewall on it as the run flats do, but bottom line, no tire hop anymore.
Old Feb 18, 2021 | 01:19 PM
Maxpowers's Avatar
Maxpowers
Yup...normal.
Old Feb 18, 2021 | 01:33 PM
seniorstorekeeper
I have also heard that the Michelin A/S 3 run flats do not have the tire hop or chatter at low speeds, they were not available when I had to buy my tires, but are now available through TireRack.com.
Old Feb 18, 2021 | 02:59 PM
Avanti's Avatar
Avanti
It's even noted in the Owner's Manual, at least for some years
Old Feb 18, 2021 | 03:27 PM
jarv33's Avatar
jarv33
Thanks guys! I will run these out. and then buy new tires. thanks again for the rapid response.
Old Feb 18, 2021 | 08:36 PM
Grand Slam's Avatar
Grand Slam
I have A/S 3 runflats and have completely forgotten about the tire hop.
Old Feb 18, 2021 | 08:39 PM
mdolandese's Avatar
mdolandese
No worries Normal like said
Old Feb 18, 2021 | 09:29 PM
Elk's Avatar
Elk
Per the manual:
Tire Chatter/Hop
When driving at slow speeds and in
very tight turns, the vehicle may
have tire chatter/hop. This is normal
and the vehicle does not require
service.
It is the result of uncompromised steering and means "performance car." Porsches, Ferraris, etc. do it as well. All season tires hop less as they are less grippy and the tire blocks do not deform as much before letting go, resulting in less judder/hop.
Enjoy it!
Old Feb 20, 2021 | 03:41 AM
Buttersvette's Avatar
Buttersvette
Same here. Cup 2 chattered like crazy. Nothing with A/S 3’s
Old Feb 20, 2021 | 12:35 PM
mdolandese's Avatar
mdolandese
[QUOTE=Buttersvette;1603034559]Same here. Cup 2 chattered like crazy. I also switched to the A/S3 from the MPSS and never heard or experienced the chatter again
Old Feb 20, 2021 | 01:14 PM
Elk's Avatar
Elk
This is because lesser tires like the A/S 3s slide on the pavement rather than grip it.
Old Feb 20, 2021 | 01:58 PM
Mad*Max's Avatar
Mad*Max
even worse in sub-freezing temps (it is called wheel hop)
Old Feb 20, 2021 | 03:32 PM
c5arlen's Avatar
c5arlen
Ackerman effect comes to mind... Perhaps?
To tire problem
Old Feb 21, 2021 | 01:34 PM
wrecker3's Avatar
wrecker3
Dump the rock throwing Pilot Sports and get Michelin A/S 3+ ZP tires and the Tire Chatter/Hop will go away !!!
Old Feb 21, 2021 | 01:58 PM
CraigStu's Avatar
CraigStu
Exactly. Ackerman is designed so the front wheels turn different amounts. The inside wheel is going through a tighter radius than the outer wheel so, if they both are turned to the same angle, then the tires would hop/slide across the pavement. 99% of street cars have Ackerman so this sliding is eliminated but...there is some cornering power to be gained by not using a complete Ackerman correction. So cars designed for max handling often have this tire hop/slide. The grip level of the tire determines whether the hop/slide is obvious or less so.
Old Feb 21, 2021 | 03:30 PM
HOXXOH's Avatar
HOXXOH
The issue is compounded with the large 19"/20" diameter wheels and short sidewall tires, especially with the extra stiffness of runflats. While great for high speed cornering and road track use, they suck at low speed tight maneuvering and ride comfort. As soon as my OEM tires are used up, I'm going to go with non-runflats on 18's/19's to get more sidewall flexibility and quietness for long road trips and local streets.
