So I have a 2019 GS. For the last several months I have noticed loss of air in my 2 rear tires. This week they were down 10psi. I took both rims off and soaped them both up and found no leaks. I checked for cracks with a magnifying glass and found none. I checked the valve stems as well no leaks. It’s been cold here in NC but 10psi????
Any ideas??
For that much of a drop in pressure, I'd say you definitely have cracked wheels. They usually start off small then develop into larger cracks. Best way to check is to dunk them into a tub of water, if you can find a large enough tub, and look for the tell tale signs of bubbles.
So I have a 2029 GS. For the last several months I have noticed loss of air in my 2 rear tires. This week they were down 10psi. I took both rims off and soaped them both up and found no leaks. I checked for cracks with a magnifying glass and found none. I checked the valve stems as well no leaks. It’s been cold here in NC but 10psi????
Any ideas??
Wow a 2029 must be into the future. JK I know what you meant 🙂
I had several cracked oem wheels on my 17 GS and found that for some cracks the amount of air that I would lose depended on what part of the wheel/crack that was parked on.
In other words, I had one crack that if I parked with the crack positioned at the bottom, I would lose very little PSI over night but if I parked with the crack anywhere else, I lost like 4-10 PSI overnight.
Any ideas??
A lot of tire places will check your tires if you tell them you have a leak and cannot find it. I had one in another car and they checked it. In my tire, it was the internal parts of the valve stem. At least, you would have a better idea of where the problem is.
You can also try taking off the wheel, fill the air pressure to 30-35lbs then spray a soapy water solution all around the wheel on the lip (That's where the cracks usually start) and watch for bubbles.
Surely someone above has already told you that "eying" wheels isn't how to find cracks and other flaws. You need to pressure check with liquid such as soapy water. Sorry, but it sounds like the s**t OEM issue has bit you, too. No one with such wheels is immune.
I know one Tech who found 2 cracked rear wheels just by eyeballing.
Two others had leaks and just did a visual inspection of the wheels up on a lift, found the cracks.
If you just look at the wheels and see cracks, then you know. If you don't find anything with just looking, and have a slow leak(s), then it's time for further inspection and the soapy water is a good next step.
