Key Fob Remote Start will not Work
Old Feb 26, 2021 | 06:05 PM
Kmadr1's Avatar
Kmadr1
Default Key Fob Remote Start will not Work
Started my 2019 Grand Sport today to move out of garage since the weather was ok and to sweep out garage, tried to start car with remote start and it did not respond, grab my 2nd key fob and same result. Also Compass needs recalibrating, is this normal after the car has sat for the winter?
Old Feb 26, 2021 | 06:30 PM
feastersss's Avatar
feastersss
C6 of Year Finalist (stock) 2019
I would start with changing batteries in the fobs, I believe they are CR2032, it is a 3 volt battery and if it gets weak it will cause starting issues.
Old Feb 26, 2021 | 06:44 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
By not respond, you mean................
Old Feb 26, 2021 | 06:45 PM
feastersss's Avatar
feastersss
Correct.....sorry!
Old Feb 26, 2021 | 06:46 PM
RonC7's Avatar
RonC7
You may not meet the conditions for an additional remote start:
FROM THE OWNERS MANUAL:
Conditions in Which Remote Start
Will Not Work
The remote start will not operate if
any of the following occur:
. The ignition is in any mode other
than off.
. The RKE transmitter is in the
vehicle.
. The hood is not closed.
. The hazard warning flashers
are on.
. There is an emission control
system malfunction.
. The engine coolant temperature
is too high.
. The oil pressure is low.
. Two remote vehicle starts, or a
remote start with an extension,
have already been used.
. The vehicle is not in P (Park)
How long has the car sat in the garage? Was it on a battery maintainer? Don't expect to lose settings or compass cal unless the battery got really low. Even disconnecting the battery will only cause loss of window indexing.
Ron
Old Feb 26, 2021 | 06:57 PM
Kmadr1's Avatar
Kmadr1
Car has been sitting since December, on battery tender, everything else is functioning as usual, all the other buttons operate as they should.
Old Feb 26, 2021 | 07:03 PM
Kmadr1's Avatar
Kmadr1
Soory, car will not start but all other buttons work fine
Old Feb 26, 2021 | 09:37 PM
eboggs_jkvl
Moderator emeritus
Does the engine turn over?
Any messages on the DIC?
Will the car start with the FOB in the slot on the steering wheel column?
More info needed? I can't read minds and I flunked clairvoyance 101 in college!
Elmer
Old Feb 27, 2021 | 08:12 AM
Kmadr1's Avatar
Kmadr1
Car starts fine with fob in pocket, and in sterling wheel slot. No messages on the DIC, just normal operations. Hoping the rain this morning washes away enough road salt so I can take a short drive to see if the DIC will show any codes.
Old Feb 27, 2021 | 08:22 AM
Kmadr1's Avatar
Kmadr1
Between the Pandemic, and the snow, I am losing my mind, It just dawned on me that the fuel is under 1/4 of a tank and if it like the other vehicles of mine they will not start by FOB with low fuel.
Old Feb 27, 2021 | 08:41 AM
eboggs_jkvl
Moderator emeritus
Never saw that in the owner's manual. I'm pretty sure it will start as long as there is fuel in the tank.
Elmer
Old Feb 27, 2021 | 10:06 AM
wayback's Avatar
wayback
Are you hitting the lock button then the start button?
Old Feb 27, 2021 | 11:37 AM
yellowstingray's Avatar
yellowstingray
If the low fuel indicator is on, I don't believe it will remote start.
Old Feb 27, 2021 | 11:39 AM
eboggs_jkvl
Moderator emeritus
That might be true, but 1/4 tank is no where near a low fuel light??
Old Feb 27, 2021 | 03:25 PM
Bill Dearborn's Avatar
Bill Dearborn
Compass recalibration is probably required because the car sat in the garage for a long period of time without access to GPS signals. It is hard to believe the batteries in both FOBs went bad at the same time in so few years. I suspect the reason why the remote start didn't work is you let the engine warm up to some degree after you pulled the car out of the garage before shutting it down. However, just to be sure things are as they should be, the first thing I would do is spend time charging the car battery to make sure it is fully charged. Then let the car sit with both doors, hood, and rear hatch closed for a few hours to make sure it is completely cooled down. Make sure you are meeting all of the conditions mentioned in RonC7s post and then try the remote start.
Bill
Old Feb 27, 2021 | 04:02 PM
PJO's Avatar
PJO
Veteran: Marine Corps
Lock the car then try remote start.
Old Feb 27, 2021 | 04:50 PM
bbrown450's Avatar
bbrown450
I always precede RS with a Lock command FWIW
To Key Fob Remote Start will not Work
Old Feb 28, 2021 | 08:12 AM
Kmadr1's Avatar
Kmadr1
I have banished myself to the Corvette Hall of Shame for a month, I have gotten so use to remote starting my other vehicle during the winter which takes two button presses to start that I was trying to start the Vette the same way completely forgot that I had to hit lock then start. This winter has really taken a toll on my mind. Thanks guys for the responses, I tell everyone that if you have a corvette you need to join the forum, plenty of knowledgeable members.
Old Feb 28, 2021 | 09:03 AM
wayback's Avatar
wayback
Don't beat yourself up too much.
I just got my 2016 a week ago. Can't tell you how many times I tried the remote start before I read the manual.
Still working my way through all the choices for the displays.
Old Feb 28, 2021 | 10:52 AM
yellow2007's Avatar
yellow2007
I can beat that......last summer I kept hitting the start button trying to put the top down.....😜
